Camry runs poorly after cam-belt change...
I thought I was doing really well with the work on my 2000 Camry 2.2. I put in a new cam-belt right on the marks, new crank an cam seals and idlers, and a new water pump and housing. New steering and alternator belts and new double-wire platinum ngk plugs, oil change, new radiator hoses, thermostat and coolant.
Car started right up, but after it warmed up while sitting there, it quits running. I thought maybe the ecm needed trained because the battery had been disconnected, so I go for a drive and the car is cutting out off-idle then it catches again with more throttle. As long as I am either giving it a quarter or more throttle or idling, I can drive the car, it accelerates okay. But at a cruise when given a little throttle to maintain speed it cuts out. Sitting at a light is a crap-shoot, it may keep running or it may not. When it does idle it is about 500rpm indicated, but after a minute or two it will start to cough and surge.
Anyway, before I did all this work the car ran absolutely perfect. It idled forever and ran faultlessly with really good power.
I thought the car was going to run better because I found the cam belt was a tooth off, and it had some cheap looking champion plugs in it with single side-wires.
Crap.....
