Coil Pack Boot
Would like to ask the advice of the Group.
I have a 1997 camry xle v6 and recently replaced plugs,wires and O2 sensors. My problem was with the coil pack boot. The existing stem upon the coil was approx. 3 inches long. The part being used is NGK CPB-T004. doesn't seem to accept that length of stem. A contact spring is flush with the flange of the boot , that rubber flange should be able to make contact with the under side of the coil. I feel i will damaging the boot and/or coil. Is there something I'm missing here? Is this a dual application part? I will patiently await your response and thank you in advance.
Best Regards,
Paul
