Crank sprocket problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2011, 04:52 PM   #1 (permalink)
View deejayphilo's Photo Gallery
Am planning to replace my CRANK SEAL of my 98 camry with 5sfe engine
but my crank sprocket it wont even come out. I used torch and fry it, stii not coming out...any suggestion?
deejayphilo is offline   Reply With Quote
Old 08-27-2011, 05:56 PM   #2 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Depending on how hot you got it with the torch, you might want to plan on getting a new crankshaft pulley. The crankshaft pulley is two parts. An outer ring held in place to the inner one that bolts to the crank. If you got the pulley hot enough to melt the rubber, you need a new one. They run $350-$375 at the dealer. You might be able to find one at a junk yard, though.
You should have used a puller like this and the crankshaft pulley would have come right off.
http://i100.photobucket.com/albums/m...ncerpulley.jpg
Here's a link to the whole thread.
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 1
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
Old 08-27-2011, 07:52 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Are you trying to remove the harmonic balancer, or the crankshaft sprocket? And take the advice of ajkalian, never heat the crank pulley with a torch.
edit - harmonic balancer and crank pulley are one in the same.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 08-27-2011, 11:58 PM   #4 (permalink)
Am removing the crank sprocket not the harmonic balancer, i already got that out..
Old 08-28-2011, 12:01 AM   #5 (permalink)
I will get a new sprocket and drill with 12mm on the existing to hook it up on my puller...
Old 08-28-2011, 12:06 AM   #6 (permalink)
^ ... Sounds rather extreme.
Have you tried a solvent, such as this from any GM dealer:
1052627 Heat Valve Lubricant (penetrating lube that has gotten rave reviews from those that use it)
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 08-28-2011, 07:25 AM   #7 (permalink)
Does your sprocket look like this? If so it should already be drilled for screws. You would use the same puller as I posted above, with my incorrect interpretation of your request for information on the crank sprocket vs. the crank pulley.
http://i100.photobucket.com/albums/m...leyremoved.jpg
There are other sprockets that have lots of holes around the circumference but only 2 of them are tapped with threads. You might have to look closely to see the threaded ones.
But some people had said that the crank sprocket doesn't have any holes at all. Sounds like you might have one of those.
Old 08-28-2011, 10:23 AM   #8 (permalink)
Yah i have the 1 ith no holes at all. I have another camry engine in my garage its 1mzfe and the cam sprocket slides out easy but this one doesn't so already know there us problem..
Old 08-28-2011, 10:36 AM   #9 (permalink)
Well that sucks. What were they thinking when they designed that one. Pretty lame not to have any way to get it off it gets stuck.
The only think I can think of, short of drilling and tapping it, would be to put the old belt back on, then get a C-clamp and tighten it on the sprocket. The old belt should keep from damaging the teeth on the gear. Then get a 2 or 3 jaw puller and hook the jaws around the C-clamp and see if you can break it free. Don't tighten down too much on the C-clamp because you will just distort the sprocket and make it tighter.
Good luck, keep us posted.
Old 08-28-2011, 01:53 PM   #10 (permalink)
GOT IT SUCK...that stupid crank sprocket almost drain my brain thinking what to do. I drilled 3/8 hole on the sprocket then used STUD POST Screw Bolt. That bolt makes room for itself to go in, force fitting itself with my impact wrench then used my puller on it. It takes 4 pull and came out with all d rust on everything. Now i just have to go in the junk yard the pull another crank sprocket for sure I wouldnt have that trouble because it should just slide out from the crank.
