97 Camry Starter System Electrical problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2011, 09:29 PM   #1 (permalink)
View mgil3000's Photo Gallery
My 97 Camry blows the 5A under dash starter fuse every time key is in start position, in park or neutral, with or without the starter relay in place. Jumping the hi power side of the relay circuit (relay removed) starts the car without problems; car runs fine. Jumping the low power side blows the fuse as above. I read 12V at the hot side of the subject fuse with key in start position; nothing when key in run. Open circuit/no resistance measured on both sides of the fuse when the key is in the start position. Any advice as to what to do next?
mgil3000 is offline   Reply With Quote
Old 08-29-2011, 02:21 AM   #2 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Remove the starter relay. If you have a new starter relay, substitute for the old one and see if the starter fuse blows.
Waste of time. The OP stated:
The short will be some where between the relay and the ignition switch, the ignition switch or even the neutral safety switch. You need to start back tracing wires. If you need it I can try to send you the wiring diagram after I get home from work this PM.
Pvt-Public is offline   Reply With Quote
Old 08-29-2011, 02:42 AM   #3 (permalink)
^ You're right ... wouldn't be the starter relay.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 08-29-2011, 09:43 AM   #4 (permalink)
A wiring diagram or where to get a reasonably priced one (starving college student!) would be great. How could you send it?
