93 Camry radiator fan always on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2011, 09:34 PM   #1 (permalink)
View newbie888's Photo Gallery
Is is normal for the radiator fan to run all the time? If I disconnect the fan switch (mine is connected on the thermostat cover), the fan runs full throttle. However, when the switch is connected and I start the car, the fan turn on and run in about half the speed and stay on all the time. It doesn't matter if the A/C is on/off. If it should be on all the time, what could be the problem?
Thank You.
newbie888 is offline   Reply With Quote
Old 08-29-2011, 09:36 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
If you have the V6(3VZ-FE), that is how the fan is designed to operate.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 08-30-2011, 08:31 AM   #3 (permalink)
Yes, it's a v6 (3VZ-FE). Thank you for the respond.
Old 08-30-2011, 11:00 AM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
the fan is hydraulic and is driven by the power steering pump so it will always be running.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-30-2011, 12:55 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
^^ Yep. When the engine is cold (or it's cold outside) the fan should spin slowly, slow enough where you can easily stop it with your hand. When it gets to around 80+ degrees Fahrenheit (26 Celsius) the fan will spin much faster, with the A/C on it may even start to "roar".
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
