Click sound when turning steer wheel? Nut loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2011, 11:30 PM   #1 (permalink)
View onthetopo's Photo Gallery
Hi,
1. My 98 Camry LE 4Cyl has a small click sound when I turn my steering wheel.
I understand that there is a recall regarding the steering wheel nut, but I already got my recall serviced 3 years ago at a dealer.
Is it loose again after 3 years?
2. My gas pedal is a bit stubborn, it takes considerable leg pressure press it down when there is no throttle, but once the engine is already throttled once, it's easy to press the gas pedal. What's wrong? Does it just need some lubricant at certain hard-to-reach locations?
Thanks a lot.
onthetopo is offline   Reply With Quote
Old 08-30-2011, 12:48 AM   #2 (permalink)
View coffee-3000's Photo Gallery
For your stubborn gas pedal issue, I think your throttle plate is sticking. I had the same problem. You think its the gas pedal itself but it's not. Just spray throttle body cleaner all over the throttle plate and the pins that it rotates on. Spray alot. You can't hurt anything. Then soak up the mess with some paper towels. You'll notice the difference right away. Give it a try. It's easy.
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
Old 08-30-2011, 03:53 AM   #3 (permalink)
View bolink654's Photo Gallery
+1 On the gas pedal. I was having the same problem though it didn't concern me, but i cleaned my throttle body and throttle plate when I had the IACV out (for an unrelated problem) and ever since the gas pedal has not stuck (it would stick in the up position)
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
Old 08-30-2011, 05:19 AM   #4 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
the clicking when turning may indicate a faulty cv shaft. check the boots for tears and check all four joints for free play.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 08-31-2011, 12:07 AM   #5 (permalink)
Hi, the clicking seems to be coming from inside the driving compartment near the steering wheel rather than underneath the car.
Old 08-31-2011, 04:54 AM   #6 (permalink)
mazdaverx7's Avatar
does it click when the vehicle is in motion or when stopped or both?
85 RX-7 GS 5spd
Old 08-31-2011, 09:21 AM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Just to be clear, the clicking occurs as you're turning the steering wheel? ... or during a sharp turn (car is rolling), with the steering wheel stationary?
BMR is offline   Reply With Quote
Old 08-31-2011, 08:14 PM   #8 (permalink)
Hi, the click sound occurs when the car is in high speed, strangely.
But the click does not occur when the car is stopped or at low speed.
