99 Camry - dash lights are gone after installing new stereo system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2011, 02:13 AM   #1 (permalink)
View jason_1's Photo Gallery
Hi,
I have a 99 camry, I replaced factory installed radio with new sony stereo system and on the same day dash lights are not glowing. I checked fuses, under steering, one 7.5 AMPS fuse blown, i changed it, but when turn the engine on, the fuse immediately blows. Looks like something wrong in the stereo installation, but the mechanic claims it's not related to the stereo installation. I never had this problem before, it happened on the same day of stereo replacement. Please help. Thanks!
Jason
jason_1 is offline   Reply With Quote
Old 08-30-2011, 02:41 AM   #2 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Did you replace the stereo or did a shop? If a shop did they messed up the wiring. Probably used the lighting wire for a power of memory wire. Keep on them until they do it right. if you did go over the wiring again. I believe you do not use the stock lighting wire for anything on an after market stereo.
Pvt-Public is offline   Reply With Quote
Old 08-30-2011, 02:46 AM   #3 (permalink)
View Nortonguy's Photo Gallery
That's nothing, I have a brother who melted his entire wiring harness from the firewall back and filled his car with thick smoke by working on his car stereo Sorry I am no help but comic relief....
Nortonguy is offline   Reply With Quote
Old 08-30-2011, 12:34 PM   #4 (permalink)
My leather so soft
Gameroom cash: $104610
View the94camryman's Photo Gallery
If the fuse keeps blowing then you have a short, probably along the accessory wire. Either take the stereo out yourself (which is extremely easy) and find the short, or take it back to the shop and tell them to fix their mess.
Mark
2000 BMW 328Ci
the94camryman is offline   Reply With Quote
Old 08-30-2011, 09:43 PM   #5 (permalink)
Thank you for the suggestions. A private mechanic installed the sterio system, it's Sony Explod model. I am planning to take out the sterio myself and see whether the fuse stays.
Old 08-30-2011, 09:48 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Something is grounding out your illumination lead. I've seen it several times. For some reason installers confuse the illumination wire with something else. Must be a color code thing.
Zembonez is offline   Reply With Quote
Old 08-30-2011, 11:54 PM   #7 (permalink)
Hi, Do you know what the color code will be? I also read somewhere there is a dim-wire, which should not be connected and just tape (without using)? Thanks.
Old 09-07-2011, 02:41 AM   #8 (permalink)
Hi All,
Problem solved!! Thanks for all your suggestions!
The problem was there is one orange wire with white strip, which should not be used as per the toyota wiring diagram. The mechanic connected this wire also, I myself found this problem using the circuit diagram available at: http://www.installdr.com/InstallDocs...PDF/869037.asp
Regards,
Jason
