Originally Posted by GreatAvalon
eyeball, any issues with rubbing? did you have to use any spacers or anything?
I read your PM
Sorry for the late reply!....NO rubbing issues with the SE's....I do have 3mm spacers on the rear, but I put them on for the widen the rear track look more that for fitting rims.
I've had lots of rims on my Coupe over the years, with different offsets..(40 O.S. usually fit fine). When I ran the TRD 18's with 45 o.s. 225/45's tires, I would rub in the rear if I had rear passengers or over large dips in the hiways, but ever so slightly. So I rolled my rear fenders.
If your able to, test fit the rims your interested in, do it. If they rub, its an ez fix
3mm Spacers on Ebay will run you 20 bucks or less, and rolling your fenders is pretty dang ez too!
Free if you do it the way I did!
The Coupe is lowered on H&R sports.
On the TRD's 225/45 Khumos
17's 40 Offset! 215/50 fuzions
18" Konigs unknowns...225/40 yokos...never rubbed!! (before the H&R's)
After the drop!
17" Megli Megalia 45 offset! 215/50 Fuzions
17" Drags..40 offset!
215/50 BFG's
