When you turn the ignition key on, nothing happens at all until you hit the steering wheel? No starter motor ... right?
A guess ... the Park Neutral Position Switch ... which keeps the engine from being started while the transmission is in forward or reverse gear.
Next time this happens, you might try moving the gear selector back and forth a few times from park to neutral.
... Could also be a wiring issue ... short or frayed insulation.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
