Help: engine light code 22 on 93 camry, water temp sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2011, 02:42 PM   #1 (permalink)
View PranaR6's Photo Gallery
Hello nation,
I need some help! My engine does not like to start after it has been sitting overnight or a few hours. It will take a couple of cranks before it will fire up, runs a little rough for a few seconds and then will run perfectly fine when its warm. After its warmed up, if I turn the engine off, it will start right back up no problems. It only gives me trouble when the car has been sitting out for awhile.
I am getting a check engine light code 22 which is the water temperature sensor circuit fault from what I looked up if I am correct.
I need to know what sensors I should check/replace and where they are. Thank you!
PranaR6 is offline   Reply With Quote
Old 09-03-2011, 03:07 PM   #2 (permalink)
Gameroom cash: $303755
Which engine does your car have? The engine coolant temperature sensor, if that is what you are referring to, is usually under a green plastic connector. If you have the 4 cylinder 5SFE engine and you are standing in front of the car, there are 2 or 3 sensors on a port to the right of the cylinder head. The engine coolant temperature sensor is the one under the green plastic connector.
Mike
Old 09-03-2011, 03:08 PM   #3 (permalink)
I4 5sfe
Old 09-03-2011, 03:11 PM   #4 (permalink)
Thank you Mike. I think the problem is that green connector. I checked it out and it is not clipping into the sensor for some reason? I'm trying to push the green connector in but it is loose for some reason.
Old 09-03-2011, 10:35 PM   #5 (permalink)
I put the new temp sensor in and it solved the check engine light. I am still having trouble with starting the car after it has been off for a couple hours. Any ideas? Thank you!
