I'll probably just search threads here about what brakes to get etc. since I'm sure that one has been answered more often then not lol. The shaking though, from what I've found, has multiple suspects.
I will be checking tires, I'm going to probably get them aligned and rotated soon.
Rotate back tires to front, front to back ... a real possibility.
Tires can get damaged internally ... cords, belts.
Fixed a severe steering drift on my '98... may be something like this is causing your vibration
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F recent timing belt, water pump
I should mention that my steering wheel is not perfectly aligned, it has to be a little off center for it to go straight. This has been happening for a while though, before the shaking started.
Maybe switching the tires around like you said would fix it, having them aligned too.
Nobody has said anything about just plain old tire balancing yet? The FIRST thing you should do is simply get your tires re-balanced. If you just noticed this starting to happen, suddenly, then you probably just lost a balancing weight off a tire somewhere. Most likely one of the front tires, if your are getting streering wheel shake. With a rear tire you will feel vibration, but not as often steering shake. Every once in a while a tire balancing weight will find a reason to pop-off, maybe a slight scrub with a curb in parking, sometimes corossion will loosen them. No big deal, just check this first, its the most likely and easiest thing to fix.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Check post # 2, a wise soul posted just that possibility.
2000 Camry IL4 5S-FE 100,000mi or 171,000km
on top of checking all 4 wheel balance (really a must in your case) I would also re-do the 4-wheel alignment (e.g. in local Firestone, they are good at it), since you mentioned having the steering wheel off center.
I have to warn you though, that at least in NJ, most of roads have a crown in middle center at the divider (famous NJ walls) in 2-way local roads or in center lane (for divided highways with multiple lanes for same direction). it may fake the feeling the steering wheel is off center, you need to check it on fairly flat and straight road, maybe some large parking lot at Walmart's or so?
I would expect there is no old dead air port strips nearby (all are in use here haha)...
I'll warn you that occasionally I've had places which just couldn't balance the tires correctly. But it usually at least changes the speed at which the shaking occurs. Internal tire damage (broken cords) can cause balancing not to work as well. That's why rotating front to back can sometimes help track down the problem. As for the steering wheel not being straight, that usually shouldn't affect how it handles. This most often happens when an alignment is done and they don't center the steering wheel correctly. Of course I suppose hitting something hard enough to throw off the alignment might show up with the wheel not being straight. But I imagine you would notice a definite 'pull'. An unbalanced tire condition usually results in shaking in about a 10 MPH range. It may be any range but if it isn't present above or below the range my advice is to check tire balance first.
BTW, I'm not a professional, just years of experience so FWIW.
I can't recommend who to see. It all depends on the skills of the person they assign to do the job. As for rotating the tires, that's something I've done to test for the problem. Recently I had two new tires installed on the front. Had vibration. Returned and the same guy checked and confirmed they were off. He redid it and I still had vibration. Swapped with rear tires and problem was gone. Went to another shop which cost more money but they balanced them correctly. I once had a similar problem but repeated balancing only changed the speed. Finally one of the guys admitted there was a known problem with those tires losing inner cords about half way thru their life. They were a brand name usually recommended for Toyota but it was years ago so the brand's not relevant. Either rotate the tires yourself to see if that helps and if it does you probably need them balanced or have them all balanced to start. Those should be the cheapest and most likely options to solve your problem. But it could always wind up being something serious like a bearing or whatnot. Again, I'm not a tire guy, or a pro. Just speaking from years of driving and helping friends.
I went to some tire place that had one of those gsp 9700 roadster machines (which are apparently the best). The balancing itself cost $15/tire + tax. The machine found that one of the tires (front right) had a problem inside it, I believe the error was excessive loadout or something. He opened the tire and fixed it for about $20...apparently when the tire was originally mounted on the rim it was done wrong (at another shop...should go after them)
