2001 Toyota Camry 4 Cylinder Codes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2011, 06:37 PM   #1 (permalink)
View pippin732's Photo Gallery
My 01 Camry is giving me the codes P0440, P0441, & P0446. I noticed about 10 days ago when I would do a cold start every morning it wouldn't turn over fully, but on the second try it would turn over. I thought it might be the fuel filter so I installed a new one. Now in the mornings it starts to sputter and then starts on the first try. However this morning after about 5 minutes of being on the engine light went on, and I came back with the codes P0440, P0441, and P0446. I just checked the gas cap and it felt like it was on okay, but I'm going to tighten it again and reset the codes. Anything beyond this I'm not to sure about. Any ideas based on what I've noticed happening when I start the motor?
pippin732 is offline   Reply With Quote
Old 09-03-2011, 07:59 PM   #2 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
The search function is your friend. The codes are the same from at least 1997 to the present.
Pvt-Public is offline   Reply With Quote
Old 09-03-2011, 08:07 PM   #3 (permalink)
I was hoping someone could help me narrow down what I need to check based on the extra information I provided.
Old 09-04-2011, 03:13 AM   #4 (permalink)
View LostSouthernStar's Photo Gallery
I have the exact same car with the exact same trouble codes. It is your EVAP system...possibly your charcoal canister, vacuum leak, faulty gas cap, etc....
I used my UltraGuage to turn off the CEL and tightened the gas cap before that to see if that's what it was. The only thing it will cause is a bit more pollution, so unless you're a tree hugger then I wouldn't worry about it.
Hope this helped!
-LSS
2001 Toyota Camry 2.2L-I4, automatic transmission with 157,000 miles.
LostSouthernStar is offline   Reply With Quote
Old 09-04-2011, 05:43 AM   #5 (permalink)
Pvt-Public's Avatar
What extra information?
That's not info. that isn't even a coherent description of a symptom. Do you mean the engine would not start? Would not crank? And what do you mean by fully? Either it cranks or it doesn't, or it starts or it doesn't.
You gave 3 of the most common codes. if you used the search there are at least 10 discussions of this very same set of codes. Why would you expect people to help you if you won't even try to help yourself?
Old 09-04-2011, 07:33 AM   #6 (permalink)
Luc
View Luc's Photo Gallery
Check here.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 09-06-2011, 05:50 PM   #7 (permalink)
I used some BG K44 and added it to my fuel. The car got progressively better over the past few days and now it starts on the first time. All I have to do now is reset the light and see if it comes back on, but I don't think it will. The 44K seems to have really cleaned out the fuel system.
Old 09-06-2011, 05:51 PM   #8 (permalink)
Maybe you have trouble with reading comprehension because other members knew exactly what I was talking about.
Old 09-06-2011, 11:23 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Check the EVAP VSV on the air filter housing and then the VSV near the canister.
See also:
Help! 98 camry CEL on, code p0441 and p0446
Old 12-31-2011, 04:30 PM   #10 (permalink)
My local, reputable Toyota dealer told me it is the EVAP vacuum switching valve and it will cost $227 for parts, labor and sales tax.
