DIY - 2000 Camry 1MZ-FE, Crankcase Blow-by and Oil Capture device, many pics. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2011, 03:16 PM   #1 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I got the idea for this DIY from this thread on TN.
Oil catch can/system...
Many thanks to the author and contributors to the thread for laying the groundwork that I built on to adapt the concept to the IMZ-FE engine.
I liked the idea of trapping the oil out of the crankcase blow-by. If you have ever looked in the Throttle Body or the ACIS (Acoustic Control Induction System) you will find a thin film of oil everywhere. Much of it comes from the blow-by of oil vapor that is sucked from the top of the valve covers and fed directly into the air stream and into the Throttle Body.
The purpose of this DIY is to make a way to capture this vapor, store it so it doesn't get into the air stream, and then a way to remove the capured oil. On a IMZ-FE engine there is a hose that runs from the front valve cover directly into the CAI which feeds the Throttle Body. Here's where the oil capure device will be installed.
The oil capture system is comprised of a jar to hold the oil, an inlet from the intake manifold and an outlet to the CAI. It's a passive system, so there shouldn't be any hit to performance, or smog problems. But I kept the old hose just in case the next time I take the car to get it smogged, I'll be able to remove everything and replace it with the stock hose. Here's a shot of the parts you will need to make it. You will need a jar of some sort, fittings, washers and some tools most everybody will have.
First, cut two holes in the jar lid. I found it's best to clamp the jar lid to a piece of wood, and use a step drill to drill the holes. Then trace out the washers onto the rubber sheet, and cut them out with sissors. Punch the center hole for the fittings. You could just buy rubber washers, but they were .90 for two at Lowes, and you will need 4, but the rubber sheeting cost .90 for the whole sheet, and I could use it to make many more if I needed them. I also planned on using part of the rubber sheet to act as a chamber divider.
The IMZ-FE engine compartment layout was such that 90 degree fittings work best, so depending on where you decide to locate the jar will determine if you come straight out of the jar with the barb fittings or use a 90 degree fitting, like I did. Since the threads are tapered on pipe fittings, I used a die to "un-taper" the threads, by flipping the die over, and started with the smaller diamater end of the die. You might be able to skip this step providing the washers are thick enough to allow the tapered threads to cinch up before the tapered threads seat fully. You'll know right away if it will work or not. I used a threaded nipple as the jam nut on the other side of the 90 degree fitting.
Other people have used steel wool as the capture material, but I had some Bronze Wool, and I decided to use it. It dissipates heat a little better, and won't rust. Although that probably isn't going to be a problem, since the jar will be filled with oil vapor.
I cut the rubber sheet to act as a divider between the inlet and the outlet ports. But there was a problem. I got a temporary case of the Dumb Ass, and didn't think to remove the hose and check the diameter of the stock hose. Turns out the hose diameters were much larger than the barbs that I had bought, and wouldn't fit properly.
So I had to go to Plan B.
Fortunately the fix was pretty easy. Rather than have barb fittings, I got a short length of threaded pipe, and cut it in half and used the outer diameter of the pipe. The stock fitting on the Valve Cover was a different size than the one on the CAI (??) but 15mm seemed to be a good compromise, so off I went to find some 15mm hose.
Pep Boys didn't have any 15mm hose but did have some 19/32" hose that looked like it would work. While I was there I wanted to find some way to filter out any loose Copper Wool strands or any other crud that might come loose in the jar and be sucked directly into the engine. I looked at several fuel filters and found one that was perfect. It was a sintered Bronze fuel filter, and as luck would have it, the inside diameter would allow me to thread it onto the end of the pipe fitting.
FWIW, I noticed while I was at Pep Boys that they had barb fittings like the ones that I got a Lowes and paid $3.74 apiece. They had the same fittings for $1.99, almost 1/2 the price, so it would pay to shop around for the fittings and save yourself some money.
After I put the revised model together, I was wondering if the rubber separator was a good idea. It might shred, and over time small rubber particles might get into the engine. So I looked around the shop to come up with a more sturdy solution. I thought about using some plastic, maybe even cutting another jar lid in two but then I found it in some stainless steel shim stock. It was .007 thick, plenty sturdy to do the job, so I cut off a piece, bent it and fitted it into the jar. It worked great.
Now I had something that was pretty much impervious to oil and I could easily disassemble everything, rinse all the parts in Lacquer Thinner, and it would clean up good as new no matter how crudded up it got.
Now to install it. I removed the stock hose, and positioned the whole assembly into where the stock hose was. It fit nicely between the cruise control cable, and some other smaller smog tubing. In fact it fit so well, I didn't even need to make any brackets to hold the jar in place. I cut a short length of hose and attached it to the CAI, then turned the fittings on the top of the jar to align with the fitting on the CAI. I did the same to the fitting on the Valve Cover. I ditched the stock clamps and replaced them with stainless steel worm drive clamps to hold the hose tightly to the fittings, which would also help to hold the jar in place and keep it from moving around.
Here's what it looks like installed.
After everything was hooked up, I started the car, and went for a drive. Pretty un-eventful. I didn't notice any change in performance. I fully expected to have some weird P9458 code thrown (something like "hose too short") but fortunately no CEL. I scanned the computer and no codes were pending. My only long term concern is that the jar might unscrew so I'll keep an eye on it. The small jar is pretty thick, so I dont' think it will break, but it's a possibilty, so to be super safe, you might want to substitute a plastic jar in place of the glass one used here. I might cut up some of the insulation that is used on water pipes to act as a cushion to prevent scuffing, but for now the jar sits in there pretty nicely
And I'm sure that many of you are wondering if you might be able to acheive the same level of filtration using an in-line filter, like the ones made by Magnafine.
Maybe.....but what's the fun in that?
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
The Following 7 Users Say Thank You to ajkalian For This Useful Post:
71Corolla (09-07-2011), BamZipPow (09-07-2011), fenixus (09-07-2011), houra (11-26-2011), N/A Camry Sleeper (09-07-2011), O_loung1 (05-17-2012), pmesfun (09-07-2011)
Old 09-07-2011, 03:23 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
nice work on the catch-jar
you like tinkering around your V6, don't you?
I think you could use a small inline fuel filter for similar purpose? not sure about flow restrictions and such, but it could work too.
I admire your super clean engine bay, mine even after pressure washing is nowhere near clean and shiny.
Old 09-07-2011, 04:07 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
This is my next project! I was thinking about installing Fram G2 fuel filter on the return hose.
Like this:
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 09-07-2011, 06:38 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
good stuff! STICKIED
The Following User Says Thank You to Mister_Perkins For This Useful Post:
ajkalian (09-07-2011)
Old 09-07-2011, 08:02 PM   #5 (permalink)
An in-line filter would work but it wouldn't store the filtered out oil. In line filters are made to be saturated with some sort of liquid, and the liquid is then forced through the filter to have the foreign particles removed.
In a way, that's what this is trying to do, by passing crankcase vapors over the wool mesh, the temperature differential between the vapors and the copper wool should condense out the oil from the vapor and then separate and collect the liquid oil in the jar.
I think stuffing some glass wool, maybe household fiberglass insulation into the inline filter would improve the collection ability. I might try that as an option to what I've got. It would be easy to do, with the compartments.
Besides, there is just something special about seeing a glass jar in the middle of a bunch of mechanical stuff, silently doing it's job, while in full view. It kinda reminds me of the balls that used to tumble around as you filled up your tank, inside the small glass dome on the gas pump.
Old 09-07-2011, 08:11 PM   #6 (permalink)
Avy
I meant as an addition to the catch can. My thought was the filter would be the last step of cleaning before the vapors re-entered the air intake. Seeing this makes me want to do the same very soon since took the time to scrub clean the intake manifold last time around. As for protection for the glass container, I think using a water bottle sleeve and cutting it shorter will keep the container safe.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 09-07-2011, 08:20 PM   #7 (permalink)
That would work fine, a little extra added filtration wouldn't hurt a bit.
Post some pics when you get it finished.
Old 09-07-2011, 09:46 PM   #8 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Thanks fer using my setup...
Using the biggest jar you can will allow less heat saturation of the vapor stream. Eventually it will git heat soaked and the smaller jar performance will suffer. I've been monitoring the temps under my hood and at my oil catch jar. Even with the big space under my hood, I've seen temps under my hood reach 175°F while driving. Temps at the oil catch jar hit 150°F during this period. I'm using industrial temperature probes (thermocouple type K) and Dwyer/Love industrial temperature measurement devices to view these temps.
Using the fuel filter after the jar can net some oil vapor...but it won't always catch everything. When you shut down yer engine, hot vapors will still rise up into the plenum from the engine via the cylinders and open intake valves...which will coat the intake system and throttle body. Using a catch system still reduces this coating significantly. You might even want to consider using a dual jar setup...
A foam soda can cooler (coozie holder) would do well to reduce the amount of damage to the glass jar.
Are you sure that's really a copper scrubber? Many "copper" scrubbers you find in the store are just copper colored steel scrubbers. A magnet can be used as a quick test but a true definitive test would be to snip a portion off and burn it. It should give off a blue-green color. Copper flame test...
The main reason why I went with a true stainless steel mesh/scrubber was fer it's corrosion resistance and heat soak properties. Using normal steel scrubbers and you set yerself up fer some serious rust as the vapors start to work on the scrubber.
Don't fergit to do a simple pressure test on yer jar to identify any air leaks it might have. Spray some soapy water around the fittings, cover one end with yer finger and blow into the other. Any bubbles will tell you you have a leak you need to fix...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 09-07-2011, 09:57 PM   #9 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
Great idea here! I love it! Much better than my setup which doesn't even vent the oily vapors into the engine - mine is 1950s style - vents to atmosphere...
I'm surprised Richierich hasn't come on here and said "It's not gonna work!"
It's good to see someone who's interested in NOT coating the insides of their motor with sludge, which we all know kills them eventually. I wonder how a water or water/meth injection system would affect sludge buildup over time. Chemically the methanol should solve the oily deposits and the water or water mixture would help transport it to the cylinders where it would get burned. Hmmm...future project? Keep up the good work!
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
Old 09-08-2011, 09:28 AM   #10 (permalink)
You are very welcome. It was a great idea that you had, and all I did was adapt it to a 6-cyl engine.
Using a standard canning jar lid will allow me to use just about any sized jar I can find. Maybe the next model will be a one quart mayonnaise jar.
Now that you mention it, I wasn't sure. I use the stuff to finish Marine Applications, since Steel Wool tends to leave small particles behind, and eventually it shows up as rust. But I checked and it isn't called Copper Wool, but Bronze Wool. I changed the description and included a picture of the package it comes in. To satisfy my curiosity I snipped off a piece of it and confirmed that it wasn't magnetic, so I'm pretty sure it isn't a bronze or copper coating over steel. And truth be told, there probably isn't any real difference in heat dissipation between the Steel Wool, and the Bronze Wool. I just liked the color of the Bronze Wool over Steel Wool, it adds a bit of color to the project.
Old 09-08-2011, 06:02 PM   #11 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Are you seeing any improvements?
Your engine is CRAZY clean
skewe is offline   Reply With Quote
Old 11-25-2011, 10:46 PM   #12 (permalink)
View mr paco's Photo Gallery
3rd Generation
I've found this info from Bill Strong at mr2oc related to 5sfe http://www.mr2oc.com/showthread.php?...3&page=1&pp=30 to be useful, if ur registered
mr paco is offline   Reply With Quote
Old 11-26-2011, 02:24 AM   #13 (permalink)
Banned
View julyaric720's Photo Gallery
Your engine is crazy clean,i like it.
julyaric720 is offline   Reply With Quote
