e-brake light came on after flooring the wagon...? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2011, 07:02 PM   #1 (permalink)
Wagon Crew
swagger_wagon468's Avatar
Gameroom cash: $343652
iTrader Score: 7 reviews
View swagger_wagon468's Photo Gallery
So... one if my new buddies was tiding with me and was asking if my wagon was fast... so I floored it to show him(first time in forever since all my mounts are shot) . After It shifted to second at about 6k... the red e-brake light came on. I pulled the e-brake release to see if somehow I pushed it in...it was still on. Then I pushed my regular brake pedal... still on. Then I pressed the gas ... and it went off.
The swag wag still drives fine. Just wondering what caused it or if anyone has ever seen this before. Should I check anything? I really don't want to replace anything as I really need to get the coupe running and I still need to replace the inner tie rod on the wagon.
Thanks guys.
Jonathan.
Shes on her way
Tint{X} Suspension{X} Camber Bolts{X} Rims{X} Sound System{X} Rear Spacers{} Header-Back Exhaust{} CAI{} Paint/Body/Kit{} Lights{}
swagger_wagon468 is offline   Reply With Quote
Old 09-07-2011, 07:08 PM   #2 (permalink)
Gameroom cash: $101400
View oopssorryy's Photo Gallery
Check your brake fluid? Mine came on, but that's because I had a leak.... Does OBDII check for a sticking caliper? If so that might be your issue.
1994 Camry LE Wagon 5S-FE with 220xxx miles.
oopssorryy is offline   Reply With Quote
Old 09-07-2011, 07:11 PM   #3 (permalink)
View Kandasan's Photo Gallery
Try checking the level of your brake fluid. I remember there was time when my brake fluid was at a certain level where accelerating, decelerating, and even the grade of hill would briefly trigger the brake light, and filling up a bit solved it.
hope this helps
Kandasan
Kandasan is offline   Reply With Quote
Old 09-07-2011, 07:20 PM   #4 (permalink)
Wagon Crew
Ill check the fluid when I get home. My brakes have made this noise ever since Kauffman Tire did my brakes. (Before I knew anything)
Its only when I say... pull into a parking spot. Then when I pull out, when I press the brakes, it sounds pike clanking metal. KAUFFMAN SUCKS! What could that be? It does sound like its coming from the front right.
Shes on her way
Old 09-07-2011, 07:25 PM   #5 (permalink)
I would defiantly check your fluid. Mine made a hellish sound right before a pin hole leak became a massive hole. Does sound like a caliper or piston issue to me. Do you ever hear a low volume noise when your driving, that gets faster the faster you go?
Old 09-07-2011, 07:43 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I think the contact points on the brake pads need to be lubed, as well as the shims.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 09-07-2011, 09:21 PM   #7 (permalink)
Wagon Crew
Oops- I never noticed any. Ill check when I go to work tomorrow.
And I will redo the brakes(complete overhaul) once the coupe is up and running. On both of them.
Shes on her way
