P0446 Evap Code Help Please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2011, 07:37 PM   #1 (permalink)
View duffer649's Photo Gallery
I have a 2001 Toyota Camry XLE (6 cylinder). For the last 3 years or so I've been getting code P0446 about every 6 months. I took it to the dealer a while back and they did a smoke test and determined the canister was ok. After about 4 times of the engine light coming on they determined the rear vacuum switching valve needed to be replaced and they replaced it. Since then the light has come on about 3 times now with the same P0446 code.
Are there any ideas as to what could be the problem?
Thanks.
duffer649 is offline   Reply With Quote
Old 09-08-2011, 08:21 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Check the wiring to the Vent Solenoid and the solenoid itself.
exerpt from http://www.obd-codes.com/p0446
Evap vent valve has only one purpose. It closes in order to seal the vent so the EVAP system can pressurize and ensure there are no leaks. Evap vent valve is usually supplied Batt. voltage with key on. The ECM's driver controls the ground, and when grounded, activates the valve (closing it). If the ECM detects a short to ground, and open,or a short to battery voltage on the control circuit, P0446 will set. Code also may refer to ECM detecting that EVAP system is unable to achieve or maintain vacuum during test.
