oil in spark plug tube - 2000 LE 2.2 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2011, 07:11 AM   #1 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
4th Generation oil in spark plug tube - 2000 LE 2.2 5sfe
Have a 2.2 camry 2000.
Got error code P300 and 302.
300-misfire
302-misfire in tube #2.
Before the code show up, the engine would shake when I put it in gear.
So I bought NGK wires and plugs.
I took out tube #1 which is closest to the passenger.
It was drenched in oil.
Do I have a leak in the seal?
Does a leak affect all the tubes?
skewe is offline   Reply With Quote
Old 09-09-2011, 07:44 AM   #2 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
You may need to replace the sparkplug tube gasket things, when you change the valve cover gasket, there are 4 gaskets that go under the valve cover over the spark plug tubes, Hopefully thats you're ONLY problem,
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Old 09-09-2011, 10:25 AM   #3 (permalink)
'06 Scion tC
mgartner0622's Avatar
View mgartner0622's Photo Gallery
How tight was the spark plug in the tube?
I noticed my car had this problem the last time I changed the spark plugs, and it was not very tight.
I have the same issue. I have replaced all the seals, the spark plugs, and basically every part except the tube itself, and my spark plugs still get covered in oil.
You don't ever have a puff of blue smoke at cold startup by chance? If so, I am told it could be the valve seals.
2006 Scion tC 5spd ~ 60k miles
mgartner0622 is offline   Reply With Quote
Old 09-09-2011, 11:06 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
IIRC, the spark plug tube screws into the head, and over time, that can loosen and leak oil into the spark plug area. The valve cover needs to come off, unscrew the tubes, apply sealant (don't remember what's recommended there), and reassemble.
Edit: Here's a DIY thread for it; starts at post #18.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
fenixus (09-09-2011)
Old 09-09-2011, 12:39 PM   #5 (permalink)
skewe's Avatar
Thanks. I put in new plugs/ignition. I will find out very soon if it is a leak internally.
Old 09-10-2011, 06:06 AM   #6 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Unless you accidentally poured oil down the tube it is leaking. The plug tubes should be dry at all times
Pvt-Public is offline   Reply With Quote
Old 09-10-2011, 12:24 PM   #7 (permalink)
Gameroom cash: $303755
Another free alternative to try before removing and resealing and reinstalling the spark plug tubes and the rubber seals under the valve cover gasket is to retighten the 4 large 30MM nuts under the plug wires to 17 ft lbs in 3 even passes, alternating between wells 1, then 3, then 2, and finally 4. Clean the oil out from the bottom of the wells and then check down there again in 500 to 1000 miles. I use a paper towel wrapped around a screwdriver for the cleaning. Many times this simple procedure cures the problem. This procedure was told to me by a former Toyota tech.
Mike
Old 09-10-2011, 05:36 PM   #8 (permalink)
Gameroom cash: $117250
View ty**20's Photo Gallery
if i'm not too late. here an great diy video to fix oil leaking onto your spark plugs.
2000 Toyota Camry LE V6 IMZFE
ty**20 is offline   Reply With Quote
