How To Clear Air Bag Light? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2011, 10:22 AM   #1 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
A couple years ago I had a problem with my '93 Camry.
When it was fixed the Air Bag light was on and has been for the last couple years.
What's the easiest way to clear this light.. a couple people have tried unsuccessfully.
zb420 is offline   Reply With Quote
Old 09-09-2011, 11:56 AM   #2 (permalink)
The Gen 3 Factory Service Manual has a section on SRS ... supplemental restraint system.
If you look at p. RS-65, there is a method to clear the SRS warning light, assuming that there is not a problem with the system.
It would be a good idea to take a look at the correct procedure for this ... so that you don't have any accidents or other problems.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
The Following User Says Thank You to dc_98_cam For This Useful Post:
zb420 (09-09-2011)
Old 09-09-2011, 12:16 PM   #3 (permalink)
Problem is I have no idea where that manual is?
Old 09-09-2011, 01:22 PM   #4 (permalink)
I have seen this being given as a source for the FSM ... Something like $15 for two days subscription .... :
https://techinfo.toyota.com/techInfo....toyota.com%2F
Old 09-09-2011, 01:24 PM   #5 (permalink)
Ok, this is what they suggest to clear that light.
what are they talking about...this is Greek to me.
I copied this from another forum a while back (they're referring to the DLC1 - data link connector under the hood):
Use two short grounding wires, one at TC and one at AB, then
> > With the key ON
> > TC one second
> > AB one second
> > TC one second
> > AB one second
> > TC one second
> But maybe 1.5 seconds, just being pretty close will work though.
> Light should be out. Report back with your results.
I approximated the time between grounding TC AND AB (roughly .5 to 1 sec) and
then held Tc to ground and the light flashed continously..I removed the ground
from TC and Voila' problem solved.
Old 09-09-2011, 01:27 PM   #6 (permalink)
This is probably why my air bag didn't deploy when I was sideswiped by that bus.. I am glad it didn't go off.. that would have been expensive to reset.
Old 09-09-2011, 01:31 PM   #7 (permalink)
Everything ok now? ... Maybe you could check for any DTC codes one more time to be sure...
Old 09-09-2011, 01:35 PM   #8 (permalink)
I didn't do this.. someone else posted it.. like I said .. it's Greek to me..
I'll run it by my mechanic..
Old 09-09-2011, 01:49 PM   #9 (permalink)
The procedure doesn't sound too complicated ... You need two wires.
Connect one end of each wire to a clean chassis ground point ... probably get some alligator clips for convenience.
The one warning in the FSM is to not make any mistakes in probing the connector .... which might cause the airbag to deploy ... so it says.
Get another opinion ... I'm just reading the manual pages.
zb420 (09-10-2011)
