Where's the Windshield Washer Pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2011, 01:48 PM   #1 (permalink)
View i_am_jim's Photo Gallery
Question Where's the Windshield Washer Pump?
Where's the windshield washer pump on a '94 Camry 6cyl and how hard is it to replace?
Two Camrys. '94 6cyl & '04 4cyl
i_am_jim is offline   Reply With Quote
Old 09-11-2011, 02:24 PM   #2 (permalink)
View yeahitsgottahemi's Photo Gallery
3rd Generation
should be on the front passenger side along with the washerjug
yeahitsgottahemi is offline   Reply With Quote
Old 09-11-2011, 03:21 PM   #3 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $908527
iTrader Score: 59 reviews
^^What Hemi said!
I had a hose come off mine once and the washer stopped working. You can access it by loosening, and pulling back the the plastic in the wheel well on the passenger side.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
The Following User Says Thank You to eyeball96 For This Useful Post:
i_am_jim (09-11-2011)
Old 09-11-2011, 04:50 PM   #4 (permalink)
Thanks for both replies. I assume this must be done from underneath, including removing the wheel and working around it?
Old 09-11-2011, 04:55 PM   #5 (permalink)
Super Moderator
eyeball96's Avatar
You assume correctly Jim
98 Honda CRV
08 GMC Crew
Old 09-11-2011, 04:59 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it's very easy to do. just jack the car up, remove the wheel and unbolt all the screws holding down the plastic fender liner extending under the washer tank area, you might need to unbolt some of those sitting in wheel well too to get better access.
you will see it once there. motor is plugged and clipped into the plastic washer tank, you will also see a Washer Fluid Level Warning sensor in the bottom of tank too.
Old 09-11-2011, 05:37 PM   #7 (permalink)
Originally Posted by fenixus View Post
. . . unbolt all the screws holding down the plastic fender liner extending under the washer tank area, you might need to unbolt some of those sitting in wheel well too to get better access.
It's been a while since I had to remove a fender liner, but unscrewing it was easy, it was getting it back in position and screwing it back in that was difficult.
Thanks for all the help
Old 11-16-2011, 11:33 AM   #8 (permalink)
Okay, I bought a pump, removed the liner, installed the new pump -- nothing.
I measured the voltage to the pump and it jumped all over the place. Usually between 4-8 volts changing constantly. I think it's supposed to be 12v steady so, I this must mean the pump wasn't the problem, it was the power to it.
Anybody know what to do when the voltage to the washer pump is bad? I have no idea where the wires come from. I assume they're from a relay somewhere, but I guess they could come from the windshield wiper motor.
Old 11-23-2011, 04:30 AM   #9 (permalink)
View SirThomas88's Photo Gallery
You should trace the wire as far back as you can, and test it at various points. A Haynes manual will have electrical diagrams in the back of it that may help you locate the proper color wire coming off the ECU.
SirThomas88 is offline   Reply With Quote
Old 11-23-2011, 09:14 AM   #10 (permalink)
Thanks for your reply. After a day or so without a reply, I elevated this to a new message and got a reply. I should have come back here and explained that. Sorry.
