Sounds like the clutch is engaging and disengaging as you step on the pedal. Because the engine idles fine but stalls if you engage the clutch. The clutch should still be ok.
If you can't get out of the 5th gear then it may be a linkage problem or a problem with the shift mechanism of the 5th gear. I would check the linkage for binding first. Remove the ends but leave the brackets and just try to shift. At least if you rule out the shifter/cable then you know it's inside the transmission.
Then it may be interlock problems before the gears/shift collar (gears/collar are fine but the shifter fork won't move). Or it maybe a shift collar problem (cable/interlock/shift fork are fine but the shift collar binds).
But if you wasn't shifting on the highway then it maybe something inside the transmission. Probably closer to the gears/shift collar than cable/interlock is my guess.
Originally Posted by newbie888
Hi,
I was driving my 93 Camry on the freeway and felt a few tugs, then the gear stuck on 5th. I can no longer shift it (up or down) and smell odor coming from the clutch. The mechanic believes the clutch is gone and something may be broken as well. The car starts but shut off if I release the clutch. It also moves if I push it when the engine is off. Does this sounds like the transmission is bad? What else it could be beside the clutch? Any idea what the problem may and/or suggestion on what I should check on the car?
Thank You
