Replacement Radiator Selection - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2011, 03:18 PM   #1 (permalink)
View toovira's Photo Gallery
95 2.2L 5SFE Auto. I see that there's 1 row (5/8") and 2 row type (1 1/16"). What's the difference? I live in Florida and I'm thinking 2 row will actually be better and I'll probably buy Koyo brand. My current radiator is 2 row and it just has too many uses of Bar's Leak. It has a slow leak and just need to replace it.
toovira is offline   Reply With Quote
Old 09-14-2011, 03:28 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I'm not sure about the difference between the two radiators, but Koyo is a great brand make sure you thoroughly flush out the leak stuff.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 09-14-2011, 08:07 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yes KoyoRad is a great aftermarket brand. TN members say the TYCs they sell on rockauto are KoyoRads (but that may change at any time).
If the mounting dimensions are the same I'd always get the 2-row. It has more cooling surface area.
If you have all the corrosion problem I'd check for the voltage and also change the coolant more often - 2 years with 50% distilled water.
With the engine cold set the digital multimeter on DCV 2V, and then dip the negative probe into the coolant in the radiator neck, without touching the sides. And touch the positive probe to the negative post of the battery. DO you read < 0.3 volt?
Old 09-14-2011, 11:28 PM   #4 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Once again, I'm selling one...
Posted in sig.
RichieRichJP is offline   Reply With Quote
Old 09-15-2011, 08:12 AM   #5 (permalink)
JohnGD - Can't measure that yet. I'm using Saltaway to strip the salt deposits (will remain in there for a week). Thanks for how to check the specific gravity though. My problem I think is the end tanks.
$350 is a bit more than I planned to spend. Very nice radiator though....alum end tanks. $75 for Koyo 1 row and $130 for 2 row is a bit more of my range.
I agree..since I'm in Florida...I figured 2 row will probably suit it better...thought I can be a bit cheaper....although I'm sure 1 row would be ok too.
Old 09-15-2011, 01:52 PM   #6 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah youll survive with the 1 row. Just go lower temp thermostat since youll be replacing that as well....
TYC on rockauto is/was Koyo. Best deal around, I paid 120$ shipped for rad,hoses thermostat and rad cap.
carsrus is offline   Reply With Quote
Old 09-15-2011, 07:43 PM   #7 (permalink)
If money is an issue then one row at about $75+shipping should work fine. Google up a 5% discount code for rockauto as well.
The 95 is a bimetal engine (aluminum cylinder head and iron engine block). I would NOT use the pink SLLC coolant. I'd use either the Toyota Red with 50% distilled water or Valvoline Asian formula pre-mixed.
It's also a good time to change the radiator cap, OEM thermostat with a jiggle valve (or Stant OE style), and the radiator hoses. I prefer Gates hoses.
Old 11-02-2011, 04:31 PM   #8 (permalink)
View just_toyota's Photo Gallery
+1 for Koyo
Just installed a Koyo Radiator on my 96 Camry and it completely matched OEM.
Had to buy it locally, spent $107 including CA tax, delivered to my house.
just_toyota is offline   Reply With Quote
