Transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2011, 03:52 PM   #1 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
4th Generation Transmission fluid
I saw some Castrol Dexron-VI in Advance Auto Parts the other day and would like to know if it's O.K. to put in my '01 camry. All I want to do is a drain and flush. I'm curious because the bottle says "for use in General Motors vehicles".
Thanks
Bill
01Camry 4 cyl
04 Highlander V6
cmryhldr is offline   Reply With Quote
Old 09-14-2011, 07:41 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I'd use Mobil-1 Fully Synthetic ATF that's good for Dexron II/III type applications at AAP. They have the ~42% off coupon code if you spend like $60.
Dexron VI is a thin fluid that's better for today's partial lock-up converter and GM's clutch-to-clutch design. But I personally would use a thicker fluid in older transmissions. That said, many TN members used Valvoline's MaxLife ATF and said it worked well. The MaxLife is a Dexron-VI thin, fully synthetic ATF.
Castrol Dexron VI is a synthetic blend. I personally put Valvoline's fully syn Dexron-VI (not MaxLife) in GM's excellent Hydramatic transmissions. Since Dexron-VI is a tight spec like Mercon-V, any brand (including Walmart's Supertech) should work in a Dexron III system. I would just use a thicker fluid like Mobil-1 in your case.
Thanks
Bill
The Following User Says Thank You to JohnGD For This Useful Post:
cmryhldr (09-15-2011)
