clock display - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2011, 07:19 AM   #1 (permalink)
View uraverageyota's Photo Gallery
clock display
morning all have a 2000 camry and the clock display comes and goes from time to time.....tap on the clock lense and the clock display returns while keeping the correct time. I'm leaning towards a faulty clock, any ideas?
uraverageyota is offline   Reply With Quote
Old 09-15-2011, 12:06 PM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
It's probably the wirings. You can check it by taking out the center gauge first. You'll have access to the clock after that.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 09-15-2011, 02:06 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
If you don't find a prob with the wiring or connector, it's possibly bad solder joints and can be repaired. Here's a DIY thread showing how to do it. My Camry's clock had the same problem, but the clock is completely different. Couldn't find any bad solder joints so I just scored a used one on eBay for about $20. A new one from the dealer was over $100, IIRC
BMR is offline   Reply With Quote
Old 09-15-2011, 06:18 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it could be something loose in the clock box itself. if wiring was getting interrupted then the clock would loose its setting and since it blacks out and then can come back with correct time setting, then my guess it's the clock's display or some internal connection in the clock module being loose.
