Engine rear main seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2011, 12:20 PM   #1 (permalink)
View bolink654's Photo Gallery
98 Camry 5SFE Auto as in sig. I'm going to have the transmission out hopefully by next week. Rounding up all the seals and misc things now.
Should I do the engine rear main seal while I'm in there? If so, how does one get to it? Obviously the flywheel has to come off... any special tools needed?
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
Old 09-15-2011, 12:41 PM   #2 (permalink)
frankjc's Avatar
View frankjc's Photo Gallery
I would change the rear main...
frankjc is offline   Reply With Quote
Old 09-15-2011, 12:57 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
yea, always change it when u pop open your tranny cuz you might as well.
it's behind the flywheel and you'll need to drill a tiny screw into the seal in order to pull it out.
and it's always a great idea to resurface the flywheel, but it's optional and depends on the condition
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 09-15-2011, 01:00 PM   #4 (permalink)
frankjc's Avatar
It's an automatic....
Old 09-15-2011, 01:04 PM   #5 (permalink)
View WaxonWaxStillOn's Photo Gallery
I don't like the idea of using a drill that close to critical surfaces, so I bought one of
these these
. Worth every penny.
1994 Camry LE
4 cyl 2.2L 5SFE, 180k miles, tan
WaxonWaxStillOn is offline   Reply With Quote
Old 09-15-2011, 01:26 PM   #6 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Originally Posted by WaxonWaxStillOn View Post
I don't like the idea of using a drill that close to critical surfaces, so I bought one of these. Worth every penny.
i have this exact same tool but don't know how to use it.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
The Following User Says Thank You to bronzemaxell For This Useful Post:
fenixus (09-16-2011)
Old 09-15-2011, 01:36 PM   #7 (permalink)
I didn't either until I watched the vid, lol. It's simple, but brilliant.
1994 Camry LE
The Following User Says Thank You to WaxonWaxStillOn For This Useful Post:
Old 09-15-2011, 02:16 PM   #8 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
I am curious why you are removing the engine?
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 09-15-2011, 02:26 PM   #9 (permalink)
I am replacing a leaking front transmission seal mainly. It's leaking at a rate of a quart per tank of gas now and getting worse.
One question... I'm lookin at the FSM. Why cant I just remove the rear main seal retainer and then do the seal outside the car? Or is it also attached to the oil pan? (looks like it but not sure)
Old 09-15-2011, 02:42 PM   #10 (permalink)
Woodyg's Avatar
interesting, so are you removing the engine and tranny as one unit?.I assume you will be replacing the VC gasket, the oil pan, gasket, Tb and waterpump?.you might consider replacing PS lines if they are old etc?
Old 09-15-2011, 03:04 PM   #11 (permalink)
I am not 100% sure yet. But probably as one unit yes.
And yes I'm going to replace alot of seals and gaskets... Probably not going to do the valve cover gasket, or anything that can be changed in the car, unless they appear to be leaking. Timing belt and water pump only have 30k on them so not doing that either. Things like PS lines depend on how they look. I need a new steering rack (leaks sometimes... but hasn't leaked in 8-10 months) and now would be the time, but money is somewhat of an issue.
Old 09-16-2011, 06:47 AM   #12 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
the rear main seal should unbolt in a plate form the engine and you should be able to change it off the car by hand. always replace the rear main seal when you have the trans down. i would not hesitate to buy the seal from Toyota, as their seals are of the highest quality!
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
bolink654 (09-16-2011)
Old 09-16-2011, 11:58 AM   #13 (permalink)
Cool, that's what I thought by lookin at the FSM. Got a rear main seal and the gasket for its retainer plate thing ordered up.
Old 09-19-2011, 09:45 AM   #14 (permalink)
http://www.youtube.com/watch?v=BtsGU2nLrJg
ok
i just did a few oil seals over the weekend using this tool
it works very good for a leaky cam seal, leaky crank shaft seal, something small, for crank shaft seal, it was difficult to push the blade in, but i used a flat head screw driver to poke a hole on the seal first, then slide the blade in, one pry, and the crank seal came out without any difficulty. this was on a 93 camry 4cyl.
while i was changing the transmission on my v6 solara
i tried to use the this tool for rear main seal, differential axle seals, this tool is too small for the job, i ended used a middle size flat head screw driver, inserted it in the rear main seal, one pry, and my rear main seal came out right away.
i almost broke this tool while trying to pull the differential axle seals, ended up using a prybar to pry out the passenger side differential seal, and huge channel lock wrench to pull out the driver side differential seal. the size of the driver side differential seal is 3" plus in diameter, the old seals were tight and dried on the outer surface, the size of the rear main seal is around 4 to 5" in diameter, but very shallow in width, mine was very easy to slide in and out.
WaxonWaxStillOn (09-19-2011)
Old 09-19-2011, 07:02 PM   #15 (permalink)
I just finished my torque converter seal, rear main seal, diff axle seals today. Well I still got some suspension stuff to bolt back up.
For the rear main, I bought this
http://www.oriellyauto.com/site/c/de...2303&ppt=C0026
So I just removed that retainer plate, did the seal outside the car.
For the axle seals I used this
http://www.harborfreight.com/seal-puller-91352.html
For the torque convertor seal, I took a paint can opener, put the business end in a vice and gave it a few whacks with a hammer to make it into a hook. Hooked the seal, stuck a screw driver through the handle of the pain can opener stuck small piece of wood on the shaft that sticks out, and pried it out... much like that tool you guys are talking about.
