Camry erratic - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2011, 02:42 PM   #1 (permalink)
cmryhldr's Avatar
View cmryhldr's Photo Gallery
4th Generation Camry erratic
2001 Camry with 117,500 miles on it. Got in the car earlier today and after about 4 blocks car started running erratically. RPM fluctuated, actually fell off momentarily and then back up. Speed was around 20 MPH. It felt like someone was switching the car off and on real fast for a few times. Then it ran fine for a block or two and did it again. It did this same thing about 3 weeks ago then was fine until today. I don't have a clue what is causing this. All I can think of is that it happened a day after filling up with gas and the temp around here has been 90 to 95 during this time. This may be a coincidence. Need some suggestions.
cmryhldr
This was the first time car had been cranked on both days.
01Camry 4 cyl
04 Highlander V6
cmryhldr is offline   Reply With Quote
Old 09-15-2011, 06:22 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
get a bottle of some fuel additive than can bind water in the tank and enrich the fuel you have in it. seems like terrible fuel mixed with water is the cause.
other than that it could be one of minor tune up items too, e.g. bad spark plugs, bad plugs wireset, clogged/damp air filter, restricted/dirty fuel filter, etc.
Old 09-15-2011, 08:20 PM   #3 (permalink)
cmryhldr's Avatar
4th Generation
The air filter and fuel filter were replaced 3 weeks ago when this first happened. The spark plugs are about a year old. NGK I think. Will try the additive and some new plug wires at the first opportunity. I'm wondering if it's bad fuel why so long between occurrences?
I'm going on a trip starting next Wed. (not on the Camry) and will be gone for 3 weeks. Thanks for the suggestions.
cmryhldr
01Camry 4 cyl
04 Highlander V6
Old 09-15-2011, 08:27 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
then you have it, likely bad fuel or some crap on bottom of the tank which blocks the fuel pump inlet or you have it in lines already (Chevron Techron concentrate is also a good fuel system cleaner, use 20oz or 2x12oz).
I think it would be less intermittent if you had water mixed with fuel, but then water usually stays on bottom and fuel sits on top of it (it's lighter), so you never know.
change those spark plug wires too, it would complete the minor tune up. NGK TE58 is the nice blue set from Advance Auto (use A123 code online for $10 off $30). bad spark plug wires could also explain the more intermittent nature of the problem.
The Following User Says Thank You to fenixus For This Useful Post:
cmryhldr (09-16-2011)
Old 09-16-2011, 12:37 PM   #5 (permalink)
cmryhldr's Avatar
4th Generation erratic Camry
O.K. I replaced the spark plug wires (NGK blue) and put a bottle of Techron in the gas tank. Lets see what happens the next few days. The car ran fine this morning on the way to the parts store and back. No more trouble after the one time yesterday.
Thinking ahead, if I have this problem again I'm thinking about removing the gas tank and cleaning it if I can. Any thoughts?
cmryhldr
01Camry 4 cyl
04 Highlander V6
Old 09-16-2011, 12:52 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
keep us posted
keeping my fingers crossed for the results
normally you never drop the tank to just clean it. run concentrated fuel system cleaners every other fill up (or with every fill up for now), that should do it in a few weeks and the fuel system should be clean as whistle.
EDIT:
another side of story, when problem was happening, was the CEL blinking (misfire detected) on instrument panel? did it ever give you any code after that?
Old 09-16-2011, 01:34 PM   #7 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
Originally Posted by fenixus View Post
keep us posted
EDIT:
that is what I was going to say.^^^^^^^^^that is a lot of work for not even kniwing if that is the issue.......use the Techron.....that stuff is the BEST...........as stated get a code reader and se if you can catch a pending code...........the ultra gauges are great and pretty cheap as an alternative.........
*if you have a MAF I would clean that also
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 09-16-2011, 02:29 PM   #8 (permalink)
cmryhldr's Avatar
4th Generation
keep us posted
EDIT:
I'll forget about dropping the tank if this happens again and use the cleaners as you suggested.
The CEL never came on at any time. With the new plug wires I have to look at the tach to see if it's still running when I stop. It's smoother now.
01Camry 4 cyl
04 Highlander V6
Old 09-16-2011, 02:31 PM   #9 (permalink)
View 66slim's Photo Gallery
Stupid Question time. I am not familiar with the ultragauge at all but have seen it mentioned on here. Can you switch its use between vehicles or is it "married" to the initial vehicle it is used on? I would maybe get one if it is versatile enough to use for two or more cars. Other wise maybe just a cheap scanner off of amazon.
66slim is offline   Reply With Quote
Old 09-16-2011, 02:38 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
I know that most Southern states have Chevron gas stations, if you have one around you, just use their fuel, all their fuel grades include some diluted Chevron Techron cleaner, so it will save you some money on buying Techron cleaner in future ... but for now use the concentrated additive.
If I had Chevron gas stations around me I would be their customer for life
It's a good sign about idle smoothing out, possibly one or more of plug wires and/or some gunk in fuel system was causing the trouble.
Old 09-16-2011, 02:50 PM   #11 (permalink)
cmryhldr's Avatar
There is a Chevron sta. about 2 miles from my house. Also I've seen a Techron logo on the pumps at a Texaco sta. Thanks for the info again
Bill
01Camry 4 cyl
04 Highlander V6
Old 09-16-2011, 03:28 PM   #12 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
Bill
I think they must own Texaco, I have a Chevron Credit Card which now is also a Texaco Card.
zb420 is offline   Reply With Quote
Old 11-02-2011, 11:12 AM   #13 (permalink)
cmryhldr's Avatar
Camry erratic
Well, either the techron and new plug wires solved my problem or the cooler weather one. No problem since I changed the plug wires. I used Texaco with techron and added some techron the first two fill-ups.
It's still in my head that the hot weather in the summer here and just after a fill up when the problem occurred could be causing the problem. My driveway is on about an 8 or 10 degree incline which puts the gas tank a little lower than if car was level. (I never mentioned this before)
I guess I'll know for sure next summer.
Thanks for all the info previously.
Bill
01Camry 4 cyl
04 Highlander V6
Old 11-02-2011, 11:34 AM   #14 (permalink)
抵抗は無駄です
fenixus's Avatar
report back in next (hopefully) hot Summer if problem returns.
Old 11-02-2011, 12:49 PM   #15 (permalink)
Woodyg's Avatar
I buy the up to 20 gallon bottles of techron when they are on sale 2 for 1. I use about 1/2 a bottle with 10 gallons of fuel a week or 2 before I plan on an oil change...........I swear by Techron......
