>150K mile suspension life? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2011, 06:57 AM   #1 (permalink)
View 5thgencamryJ's Photo Gallery
4th Generation >150K mile suspension life?
How long will the suspension parts (control arm, sway bushings, etc) hold up in your experience, except for struts?
5thgencamryJ is offline   Reply With Quote
Old 09-16-2011, 08:34 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
It all depends on a buncha factors. Toyota stuff is pretty tough and many components wont go bad for a long time.
Im at 135k or so and the only suspension component ive touched are the rear sway bushings. Ive needed struts for a while though (past 20k miles) but Ive been letting it slide....
But ive seen cars with under 100k need c-arms and ball joints and a whole slew of stuff. The way you drive and road condition is critical. Hit a couple big potholes and curbs and your gonna need work.
carsrus is offline   Reply With Quote
Old 09-16-2011, 11:19 AM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
literally.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 09-16-2011, 11:48 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
At 319k miles, my Camry's needed:
All 4 struts (just once)
Front lower spring insulators
Rear strut upper mounts (in hindsight, they were probably OK)
Left rear suspension control arm #2, the rear-most one
Front lower control arm rubber bushings.
All 4 sway bar bushings
At 248k, my Avalon:
Struts, all 4. The spring insulators on the rears were also replaced at the same time. The struts leaked oil on 'em and they were crumbling into pieces. As far as I know, that's all.
But, as carsrus said, it's highly, highly dependent on driving habits and your typical road conditions.
BMR is offline   Reply With Quote
Old 09-19-2011, 02:14 PM   #5 (permalink)
rear sway bushing
[QUOTE=carsrus;3662915]It all depends on a buncha factors. Toyota stuff is pretty tough and many components wont go bad for a long time.
How did you know you need sway bushings? Noise? handling?
Old 09-19-2011, 02:15 PM   #6 (permalink)
spring insulator
Originally Posted by BMR View Post
At 248k, my Avalon:
How did you know you need spring insulators? How much are they at autoparts store
Old 09-19-2011, 09:11 PM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
On the Avy, I could see that strut oil had leaked down onto them, and they were deteriorated to the point they were crumbling. On the Camry, I saw they were worn thru where the springs were resting on them, and had squeezed out and were dangling. They're pretty cheap, like $10 or so each. I got all mine at Rockauto.com. They're slightly more at the auto parts stores, but not enough to matter. I was buying my struts at Rockauto, so it was just convenient to get the other parts there too.
Old 09-20-2011, 10:16 AM   #8 (permalink)
[quote=5thgencamryJ;3665218]
Noise, I had a horrific clank in the rear I thought were strut mounts but it was just the sway bushings. Its a common thing to look over and many people replace struts b/c the sway bar is clanking around.
I might throw 2 quick struts on the front in the spring, since the ride is really starting to bother me.
Old 09-20-2011, 11:48 AM   #9 (permalink)
01 Solara/00 Sienna
Cranky-Condor's Avatar
View Cranky-Condor's Photo Gallery
I replaced our 2000 Sienna's total front suspension at 135,000.... everything but the spring. and now with 100,000 I'm doing the same thing to our 01 Solara. The front lower control arm bushings just fell apart on both vehicles. And don't buy cheap crap. The ball joints that came with the lower control arm failed after 8 months so I replaced them with Moogs last weekend.
2001 Solara + 2000 Sienna
Cranky-Condor is offline   Reply With Quote
