seal leaks .. help identify - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2011, 01:38 AM   #1 (permalink)
View smilecow's Photo Gallery
I own a 99 4 cylinder camry .
I just changed the right cv joint two days ago and yesdays found the transmission fluid was leaking where the cv joint goes.
the culprint was the seal..
look at the pic
what is the name of the seal?
Is it the differential seal?
how should I remove it?
thank you
smilecow is offline   Reply With Quote
Old 09-18-2011, 08:20 AM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
look at the pic
thank you
it looks like cv axle seal,
definetely need to redo the cv joint exercise again,because cv axle has to come out first
differential shaft seal under $10 if bought online, almost $20 if walk in to stealership
i just use a flathead prybar to pry out
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
