Differential pin? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2011, 08:28 AM   #1 (permalink)
View Keith Richards's Photo Gallery
Differential pin?
Hi everyone.
I've been having a clunk when I shift into reverse (98 Lexus ES300 (transmission A541E)), especially when it's warm (it's puzzling that it's barely noticeable in the morning on cold start and the engine is idling at 1800 rpm!). Also, it is shifting not so smooth into all gears as it was.
Mister_Perkins posted the following reply to a similar question a few months ago:
Could be mount issue. Check to see if your mounts are Cracking (Transmission and dog-bone). The front and back will be harder to diagnose.
Is it shifting hard into the gears??
If so, a possibility COULD be that the pin inside the differential walked itself out a bit and now when you shift it into Gear (Park to Drive) or Neutral to Drive or Park to Reverse, the differential is moving the distance that the pin has walked out.
if you dont notice any harsh engagement between P, R, or D I would say the differential pin is probably OK.
So... my question is: How can I check the so-called differential pin?
Thanks in advance!
Keith Richards is offline   Reply With Quote
