Does anyone know if you can buy from the dealer just the drive component within the oil pump? Is it a replaceable item without buying the entire assy?
On my 1998 Camry with the 2.2L, I'm underway with replacing the timing belt, water pump, crank/camshaft seals, etc. and hoping to solve a minor oil leak in the process. I'm following the excellent 2-part "How to change your Timing Belt" write-up posted as sticky in this forum.
I get to the point where I dismantle the oil pump and remove its drive gear so I can replace the oil seal on the shaft. I noticed that the oem seal has worn a groove into the shaft, thus allowing oil to seep past causing my leak.
I'm really hesitant to put a new seal on a worn shaft. If the shaft is unavailable, an alternative route would be to buy a
new oil pump assembly from a parts supplier.
Anyone else encounter this issue?
