What was the code(s)? I'm guessing P0420? Is this a 4 or 6 cylinder? I'm guessing auto transmission?
Best thing to do is use a engine diagnostics program like AutoTap or AutoEnginuity that has data logging. That way you can see what was going on when happens. I'm guessing yer mechanic has already checked fer the obvious like spark plugs, the coils?
Did yer mechanic perform a smoke test to eliminate any possible vacuum leaks? How clean is that throttle body? When was the last time the timing belt was changed?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
