Hey guys, haven't been back on here for a bit.
Got a
MAJOR oil leak I need some assistance to identify and get repaired ASAP.
1997 ES300 3.0L 97,000 miles, my mothers I bought her 3 years ago.
It has not had it's belt and pulley maintenance yet.
I did look in the Camry FAQ first, but didn't see any titles relating to this problem.
I have a MAJOR leak on the front of the engine (Pass side). Maybe a quart per 20 minutes.
It's right above the crank pulley, and looks to be coming out of where a white plug sensor goes in.
I've circled the area in the photograph.
I can't actually see in there well enough to make a 100% positive ID.
I can see it's pouring out and that seems to be the location it's coming from.
Nothing above it is showing oil streaming, so I think this is the area.
Read alot of threads about cam seal leaks and it only takes 15 minutes to replace.
However I have no idea where the cam is located from the front of this engine.
Engine bay is so damn tight and I can't get in there any better to see......
Does anyone have a Lexus 3.0L front engine image that shows the ID of all the components??
I'm not too savvy with the import motors at all.
Any help to ID this problem is GREATLY appreciated.
I'm out of a car until I fix my mothers problem.
I'm sure you guys know how it is taking care of your parents.
If anyone knows the problem and can ballpark the shop repair hours, I'm all ears.
Here's the pic and the video.
Video showing the oil streaming out. This is from the wheel well with the flap removed.
