Ok. I been talking about doing this on and off on here for a few months. Also been reading on the various ways people are doing this. My main problem was that my transmission was leaking fluid out around the torque convertor. It started at just a few drops and grew to a quart every 400-500 miles.
Of course if I'm going to have it out, I should do the rear main seal and the axle seals too. Did the trans filter and pan gasket too.
Now I did have access to 2 engine hoist and a transmission jack. But I wanted to see if there was another way, perhaps a cheaper way, you know for people that cant get a hoist or transmission jack. Plus I would have had to borrow the trans jack from a former fellow employee, and my bro-in-law had a engine hoist, and a guy my wife works with has one too. They all offered, though.
My idea was to buy this
http://www.harborfreight.com/1000-lb...bar-96524.html
And I already have one of these, great little thing to have around.
http://www.harborfreight.com/1-4-qua...ist-67144.html
I was gonna buy some eye bolts and run 'em through that support bar, hook up the 1/4 ton chain fall, and lower the trans out the bottom onto a creeper (
http://www.harborfreight.com/folding...pad-93896.html ) Since I already had 2 of them.
HOWEVER the nearest Harbor Freight is about 45 miles from me. I called, they had 2 support bars. I drove down there... They did not have any and wouldn't have any until a week from today. That blows. But failure wasn't an option. I need the car in 4 days. So I made a trip to a hardware store and $54 dollars later I had this.
Yes it looks like its bending. I did not lay a straight edge on it, so I don't know for sure. Didn't want to know, honestly. I wouldn't recomend this. If I was going to do it again, I'd use bigger pipe, or buy the actual thing from harbor freight. That was 2" OD water pipe.
I do not intend this to be a DIY. There is a full picture DIY here from someone else (not much descriptions though)
http://www.pbase.com/kocho/camry&page=1 Just showing what I did and how I did it.
Now did it work? Well lets have some pictures.
Subframe out. You will need 3 jacks to get it back in though.
Chains wrapped around transmission
Hooked to the 1/4 ton chain hoist.
Will it work? Yes it will.
Lowering it down.
Underneath
Another pic underneath while lowering it down.
And it is out
Now can you get it back in the same way? You sure can because its back in right now, subframe is back in too. Also, I did not fool with anything on the passenger side except those 3 bolts on the ball joint, and that axle bearing thing... I pulled the snap-ring out and slid the axle out of the trans. Like the guy in the link I posted did.
