99 camry Backup Lights Come on with tail Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2011, 10:05 AM   #1 (permalink)
View lger's Photo Gallery
My 99 camry back-up lights come on whenever the tail lights are on. Basically, the back-up lights perform just like tail lights, but no response to the gear. For example, during the night, or in a garage where is quite dark and the tail lights come on, the back-up lights come on.
Any idea?
lger is offline   Reply With Quote
Old 09-20-2011, 10:32 AM   #2 (permalink)
View WaxonWaxStillOn's Photo Gallery
Has it been like this since you've owned the car, or did it just happen all of a sudden?
1994 Camry LE
4 cyl 2.2L 5SFE, 180k miles, tan
WaxonWaxStillOn is offline   Reply With Quote
Old 09-20-2011, 10:51 AM   #3 (permalink)
Just recently. Also I just got my rear bumper replaced. Don't know whether these are related.
Old 09-20-2011, 05:51 PM   #4 (permalink)
Gameroom cash: $303755
Open up the loom of wires in the trunk by the driver's side trunk hiinge. Many times the wires inside ther frey and break from all the flexing they are exposed to as the trunk is constantly opened and closed. Notice the color of wires leading to the back up lights and inspect those carefully. Fix what you find.
Mike
Old 05-20-2012, 01:33 PM   #5 (permalink)
View brinton's Photo Gallery
Back up Lights Not working
Back up lights do not work on 2001 Camray. Gauge fuse ok. I removed plug from backup light switch on transmission and shorted terminal. Lights still not on. Not sure i have right switch It does not look like switch in Hayes repair manual. Also can't find switch in electrical diagrams.
Help please.
brinton is offline   Reply With Quote
Old 05-20-2012, 04:42 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
As mentioned double check the wirings.
Old 05-20-2012, 07:44 PM   #7 (permalink)
Back up light problem
I confirmed switch ok by measuring short across it when shift is in reverse. Also measured voltage on red wire at swith is 12 volt so problem looks like in wiring unless both bulbs are blown which is unlikely. Will advise progress. Still can't find switch and light in wiring diagram.
Old 05-21-2012, 02:34 PM   #8 (permalink)
From my post above:
Open up the loom of wires in the trunk by the driver's side trunk hiinge. Many times the wires inside there frey and break from all the flexing they are exposed to as the trunk is constantly opened and closed. Notice the color of wires leading to the back up lights and inspect those carefully. Fix what you find.
Mike
Old 05-23-2012, 08:06 PM   #9 (permalink)
Back up light problem solved
Mike:
thanks for tip, but I resolved it before I received your msg. I opened bundle near left trunk hinge and found 2 wires broken and almost all others damaged. Other broken wire went to trunk open warning light. End of plastic wire cover cuts into wires as trunk is moved. Poor design on part of Toyoto. Problem could have been easily averted.
Brint
Old 05-23-2012, 09:53 PM   #10 (permalink)
Originally Posted by brinton View Post
Mike:
Brint
You are correct; it's a bad design. Toyota is still using the dame design on my 2007 Camry. I haven't checked a 2012 (generation 7) yet, but it wouldn't surprise me if they are still using it on that model too.
Mike
