O/D jerking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 08:22 AM   #1 (permalink)
View baahaani's Photo Gallery
USA O/D jerking
When i put it in o/d when the car is cold it drive fine but after 15 mins car starts jerking every time i press the gas.
baahaani is offline   Reply With Quote
Old 09-22-2011, 07:26 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
How good is yer ATF?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 09-22-2011, 08:45 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Check ATF level and condition first.
I'd drop the pan and replace the strainer too. NAPA a Wix kit with rubber gasket for about $20. Make sure to leave no lint in the pan and that the magnets don't block the strainer pickup port. Measure what you drain out and add that amount of new ATF back in.
Depending on how much OP wants to spend:
Walmart SuperTech ATF (dino) ~$2.7/qt when I last checked
Walmart SuperTech Mercon-V ~$3.9/qt
Castrol Import Multi-vehicles ATF ~$5/qt
Mobil-1 synthetic ATF ~$5.6/qt with Advance Auto coupon (the one with 42% off)
Tags
o/d jerking
