Harmonic Balancer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 09:57 AM   #1 (permalink)
View calel1's Photo Gallery
Harmonic Balancer
Hi, I have a 99 camry 4cyl and I have a oil leak some where on the front of the engine.I pulled the harmonic balancer and the timing belt cover to access the area.The leak only happens when the engine is running and my question is.Can I crank the engine and run it at an idle speed without the harmonic balancer being on the crank shaft without doing any damage.I cannot visibly see the leak without doing this because it needs to build up pressue before it starts to leak.
Thanks for any help you can give.
calel1 is offline   Reply With Quote
Old 09-22-2011, 10:05 AM   #2 (permalink)
View curry.style's Photo Gallery
It's probably leaking from the oil pump seal. I'd go ahead and replace all the crank and cam seals as well. Those parts are all pretty cheap.
331,000 miles and the wife's 1995 Camry LE finally bit the dust...but we can rebuild it, we have the technology...
1993 Camry LE wagon, 4 cyl, 5 spd swapped...more to come...
curry.style is offline   Reply With Quote
The Following User Says Thank You to curry.style For This Useful Post:
calel1 (09-22-2011)
Old 09-22-2011, 02:36 PM   #3 (permalink)
Thank you for the reply but I would still like to know about cranking the engine without the harmonic balancer.
Old 09-22-2011, 06:36 PM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Don't run the engine without the crank pulley, oil will piss out of the engine at a high rate. The sealing surface for the crankshaft seal is on the harmonic balancer.
BTW, your leak is probably coming from the oil pump spaghetti gasket.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
calel1 (09-23-2011)
Old 09-22-2011, 09:39 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I thought the sealing surface of the crank seal is at the spring loaded area of the shaft seal.
Anyways never run the engine without the balancer. The engine will run rough and the crankshaft can snap.
The Following User Says Thank You to JohnGD For This Useful Post:
calel1 (09-23-2011)
Old 09-22-2011, 09:55 PM   #6 (permalink)
71Corolla's Avatar
What I posted is wrong, I'll just back out of this thread now.
Old 09-23-2011, 05:37 AM   #7 (permalink)
Thanks to all of you for the responses..
Old 09-23-2011, 05:51 AM   #8 (permalink)
lurker noob
View GA-Guy's Photo Gallery
Somewhat irrelevant but mr2/celica 5S-FEs did not have the balance shafts.
1996 Camry DX SXV10
"Christina" 175,000 miles and counting
2006 Corolla CE E120
"Hitomi" 58,000 miles and counting
GA-Guy is offline   Reply With Quote
