1998 Camry 5s-fe tube identification assistance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2011, 10:08 AM   #1 (permalink)
View Savio's Photo Gallery
4th Generation 1998 Camry 5s-fe tube identification assistance
Hi all,
I took some pictures from the last time I was doing some work on my car and found some tubes that were cracking. I know the first tube is to the PCV Valve to the intake and the other I'm not exactly sure but heading towards the air filter.
I need some help identifying which part it is and if it's something I can go to AutoZone/local store to find a replacement size or the dealership parts the best way to go.
Also, would driving with these around have any issues with the car?
Savio is offline   Reply With Quote
Old 09-22-2011, 10:20 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Just go to your favorite part store with the old vacuum lines. They cost 1$ a foot.
Eventually the lines will start letting in air and cause a vac leak.
carsrus is offline   Reply With Quote
Old 09-22-2011, 12:47 PM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
Since there will be oil fumes get fuel line not vacuum line. It will hold up to petroleum fumes longer.
Pvt-Public is offline   Reply With Quote
The Following User Says Thank You to Pvt-Public For This Useful Post:
Savio (10-01-2011)
Old 09-22-2011, 01:37 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
Positive Crankcase Ventilation (PCV) hose connecting the PCV valve and intake chamber.
it's like $5 at dealer, comes preformed, just move the clips, unplug it and swap it (you can re-use the clips).
The Following User Says Thank You to fenixus For This Useful Post:
Savio (10-01-2011)
Old 10-01-2011, 07:58 AM   #5 (permalink)
What about the one on the right side? What is that one called?
Old 10-02-2011, 12:22 PM   #6 (permalink)
For future reference for anyone who needs those hoses, the part numbers are as follows from the dealer:
Part#1226274100 | Hose, Ventilation - $10.38
Part#1226074070 | Hose Assy, Vent - $15.03
Old 10-04-2011, 02:20 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
that is also the PCV hose, but this one allows "breathing" of valve cover through the intake hose.
Tags
5sfe, identification, tube, vacuum
