3VZ-FE valve cover gasket DIY Writeup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2011, 02:25 PM   #1 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
3rd Generation 3VZ-FE valve cover gasket DIY Writeup
this shortened writeup will cover changing the valve cover gaskets on a Camry with a 3VZ-FE engine. i will later add the torque specs as well as all tools needed with pictures of each tool. all work performed was by myself on my 92 Carmy SE with a 3VZ-FE and a 5spd manual trans.
-remove the left bank engine cover and the upper half of the air box with intake tube:
-remove the solenoid rack and anv vacuum lines blocking the left bank:
-remove the cold start fuel injector's fuel line, ground wire, and the pcv valve's hose and accociated vacuum lines:
-remove the rear egr tube, rear engine hanger and the rear vacuum lines. you will also need to disconnect the throttle sensor on the rear of the throttle body:
-remove the two nuts and the two bolts holding the upper intake manifold to the lower manifold:
-lift the upper intake off and leave the throttle body attached:
now you are ready to remove each valve cover. they are held on with 10mm bolts. the bolts are special and have rubber washers with a metal head under each bolt. these washer should be changed EVERY time the gaskets are replaced.
the bolts that come off will probably look like this:
you will need these new washers form Toyota:
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
71Corolla (09-23-2011)
Old 09-23-2011, 02:26 PM   #2 (permalink)
mazdaverx7's Avatar
the valve covers will probably look like the when removed:
clean them thoroughly:
install the new spark plug tube seals first and then the valve cover gasket:
apply sealant to each corner of the mating surface on the cylinder head where the valve cover gasket meets the head. ensure that you clean the surface of any oil or debris. place the valve cover in position and torque the bolts in steps until the proper torque is reached. overtorquing will result in cracking the aluminum valve cover. re-install each component in the reverse order of removal, noting the the torque specs for the upper to lower intake manifold. the toughest part of the process for me was wiggling the rear harness up enough so that i was able to remove the right (rear) valve cover. this is a tight fit.
85 RX-7 GS 5spd
JohnGD (09-24-2011)
Old 09-23-2011, 02:58 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Stickied
Old 09-23-2011, 05:46 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Nice DIY. It's a good idea to stuff rags or something into the intake manifold ports to prevent dropped screws or whatever from falling in.
Also a good time to check the valve/cam clearances.
BMR is offline   Reply With Quote
Old 09-23-2011, 09:10 PM   #5 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Thanks for the write-up! I always give up when attempting to make my own.
How did you get the valve cover so clean?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 09-23-2011, 09:56 PM   #6 (permalink)
mazdaverx7's Avatar
i cleaned the valve covers with brake cleaner and then engine degreaser and hot water. the oil was really caked on them and was hard to get off. i was leary to throw them in the hot tank so i just did it by hand. i have had a couple people ask for a valve cover writeup so i figured i'd post a quick one and add to it within the next day or so. i actually did this last fall but kept forgetting to post the writeup.
85 RX-7 GS 5spd
Old 09-24-2011, 01:42 AM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Nice DIY. Is that the new silicone Fel-Pro red gasket? Or did the cover gasket come from the dealer?
Did you reseal the semicircular plugs?
Old 09-24-2011, 01:48 AM   #8 (permalink)
mazdaverx7's Avatar
the spark plug tube seals were new as well. they just happened to be black just as the old ones were. the gasket kit that i used was the FEL-PRO silicone set. i give it the highest marks. far better than the rubber set i installed back in 2005! i still have the old gaskets and the box that the new gaskets came in. i'll take a picture of it tonight on my lunch break or tomorrow afternoon when i wake up and i'll post the picture with the part number.
85 RX-7 GS 5spd
Old 09-26-2011, 09:31 AM   #9 (permalink)
mazdaverx7's Avatar
today i will be taking the time to include all of the torque specs and special tools needed to perform this repair.
85 RX-7 GS 5spd
Old 09-26-2011, 01:49 PM   #10 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
hehe, looks like exactly what i did a month and half ago.
good job
i did one more item while i was at it. i replaced the PCV valve and grommet.
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 09-27-2011, 01:58 PM   #11 (permalink)
mazdaverx7's Avatar
i replaced it when i did the valve cover job as well. i just didn't add that in there. the grommet was hard as a rock and it was difficult to remove.
85 RX-7 GS 5spd
Old 10-08-2011, 10:09 PM   #12 (permalink)
TN USER
razr988's Avatar
View razr988's Photo Gallery
Good thing i did this! Two of the spark plug tube seals were cracked(Is it bad for the car? I guess) . To bad i don't get any of the parts till Tuesday.
Good DIY.
-est.1991-
-93 camry V6 SE
-http://www.cardomain.com/ride/3864106/1993-toyota-camry-se-sedan-4d
razr988 is offline   Reply With Quote
Old 10-09-2011, 06:25 AM   #13 (permalink)
mazdaverx7's Avatar
thanks! the spark plug tube seals, seal the oil from getting into the spark plug wells. the oil will seep in there and foul the plug and can ruin the rubber on the wire's boot. the spark plug tube seals can be stubborn to remove so have patience.
85 RX-7 GS 5spd
Old 10-09-2011, 07:41 AM   #14 (permalink)
TN USER
razr988's Avatar
Thank you once again! I wouldnt of attempt changing nothing if there was no DIY of this.
And I've been driving like that for a while. Good thing nothing happen. Those things are stubborn but two of them came out easily. That's how bad they were. The inside is so clean for a 230k mile car. . Well maintenance. lol
I dont know if you did it but do you recommend changing the oil also?
-est.1991-
-93 camry V6 SE
Old 10-09-2011, 03:20 PM   #15 (permalink)
mazdaverx7's Avatar
yeah, i changed the oil at the same time i changed the valve cover gaskets. figured it couldn't hurt to do while i was in there.
85 RX-7 GS 5spd
