94 Camry V6 Exhaust Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2011, 10:15 PM   #1 (permalink)
View keith_Julie's Photo Gallery
I just bought a 94 Camry V6 for my daughter. It has 186,000 miles and what was supposedly a muffler exhaust leak. Upon inspecting it from the top side, I found that the exhaust leak was up close to the engine. I assumed it was something like a flex pipe or something and have yet to get underneath it so am not sure what components make up the exhaust system in this area. Those of you experienced with these cars, what is this leak from most likely? A gasket, flex pipe or something else???
keith_Julie is offline   Reply With Quote
Old 09-24-2011, 02:08 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
more than likely the front y-pipe's flex pipes have given up the ghost. where in OH are you located? i bought my new y-pipe from advance auto parts. decent quality with a life expentancy of about 5 or 6 years. in this picture, you can see the y-pipe with flex pipes:
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-24-2011, 06:20 AM   #3 (permalink)
Ohhhh, there are flex connections in the pipe... looks like a fun one to replace!! How hard is it to replace this one?
Old 09-24-2011, 06:28 AM   #4 (permalink)
Are the connections too the manifolds and cat with studs or bolts? My worst fear is breaking off studs in the manifold...
Old 09-24-2011, 06:36 AM   #5 (permalink)
mazdaverx7's Avatar
there are two studs in each manifold. surprisingly Toyota uses stainless nuts and mine came off with relative ease. i did work them slowly and i applied antiseize as i had in 2005 in anticipation for future removal. the pipe to converter uses two bolts. you will also have to remove the center y-pipe hanger form the subframe. only two 12mm bolts secure it and it makes removing the y-pipe worlds easier. in addition to the y-pipe you will also need two gaskets for the y-pipe to manifold flanges and one y-pipe to converter gasket. i replaced the converter bolts and ensured the hanger bolts had a die run down them and the subframe holes tapped to clean the threads. the hanger bolts were then greased as was the y-pipe hanger tab. old hanger tab was seized in the rubber hanger.
85 RX-7 GS 5spd
