Originally Posted by dipesh
So, sometimes when I start my car it doesn't start. The whole power in my car is OFF. Even sometimes when I park my car after using it in my school parking lot, the whole power of the car is off and turns back on when I open my engine and move the battery line it works or sometimes the power is ON by itself but the whole system is resetted. I checked the battery line which is tight and the battery is new bought from walmart of jan 2011.
Any solutions?
Most likely you have a loose or bad connection somewhere since yer power comes back on when you wiggle the wire.
Snap a few photos of yer engine bay and yer battery terminals and post those up.
I would even guess that you might have a bad ground, too.
Personally, I would pull the negative wire first, then the positive. Clean all yer connections even if you have to take the connector apart and soak them in a mixed solution of baking soda and water. Wire brush the connections until shiny/bright. Reassemble and hook up the positive first...then the negative.
You might want to check the power going to the fuse box as well. It could be loose...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
