98 Camry won't start.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-24-2011, 05:55 PM   #1 (permalink)
View FishBut's Photo Gallery
Hello there, noob here. Browsing the internet for info on fixing my son's car and came across this site.
98 Camry LE V6. No start. Had the battery testing and it is putting out about 870 amps and other electrical stuff (windows, lights, etc.) work fine. Just no engine turnover. Can't really hear any starter clicking.....would like to get this thing going tomorrow and avoid towing to mechanic. Thinking bad starter but wanted to see if anyone had any suggestions. Any advice would be greatly appreciated!
FishBut is offline   Reply With Quote
Old 09-24-2011, 06:42 PM   #2 (permalink)
Gameroom cash: $114276
View reluctantmechanic's Photo Gallery
5sp? Can you pop start it? I've always heard a light tapping from my starter when it wouldnt work....and I think a starter gives you clues before it dies all together.
One other quickie...make sure the are is in park, pushed up hard in park....the car will not start if it things the trans is engaged in R...which sometimes happens.
Evap Canister, Radio, Rear Speakers from a 99 Camry approx 110k miles
50 Bucks, and I will pay shipping.
Click here for a picture! http://i167.photobucket.com/albums/u...r/DSCN3826.jpg
reluctantmechanic is offline   Reply With Quote
Old 09-24-2011, 06:46 PM   #3 (permalink)
Nah it is automatic. I did play with the shift lever....can try that again just to make sure.
Old 09-25-2011, 11:47 AM   #4 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Did you try starting it in Neutral? Does the shift selector indicator work? If not, it could be a bad park neutral safety switch. There is a sticky fer cleaning the switch...
Did you check all yer fuses?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 09-25-2011, 03:26 PM   #5 (permalink)
I checked voltage at the starter and nothing. I put a test lead from the starter solenoid straight to pos battery and fired right up. Ok guessing this neutral safety switch or ignition switch. What should be my next test or step? I did try to start it in neutral and no dice. I'll do some more searching here as well. Thanks!
Old 09-25-2011, 03:27 PM   #6 (permalink)
PS - the shift selector indicator does work.....
Old 09-25-2011, 06:59 PM   #7 (permalink)
BamZipPow's Avatar
Since yer shift selector indicator works...I would say the Park Neutral Switch is probably good.
Looking over my 2001 EWD, there is a 5A Starter fuse...and a Starter relay. You might want to carefully check those.
The 5A fuse provides protected power to the solenoid side of the Starter relay.
Fuses are located behind the driver's side courtesy dash pocket.
Here's the map of the fuse panel...
The 5A fuse is the only 5A fuse in the panel...2nd row from the right, top fuse.
Old 09-25-2011, 08:54 PM   #8 (permalink)
Hey thanks BZP.....I checked the price of a neutral safety switch and yes I sincerely hope it is ok.
I did pull the 5 amp starter fuse and it is fine.
Where is the starter relay? Is it in the fuse box in the engine compartment? Not sure how to test that this other than buying a new one.
Old 09-25-2011, 09:36 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it could be worn out starter contacts. as a test you can smack the starter cylinder under hood with a hammer (and some extension), it usually starts this way if only the contacts are bad. check all the fuses in the box, e.g. 15A EFI fuse and a few other in there under hood.
if you suspect a bad relay, then knocking on it hard can make it work/click, other than that you need to test them with multimeter and a power source (.e.g. 9V battery or car's battery).
Old 09-25-2011, 09:40 PM   #10 (permalink)
BamZipPow's Avatar
The starter relay is located in the engine bay fuse box.
The blue/purple-ish relay in the upper left corner is the starter relay...as indicated by the diagram under the fuse box cover.
Pull the relay out and test it this way. You want to check pins 1 and 2 with a multimeter. It's the solenoid connections. If it's open (no reading in ohms) then you need to replace the relay. If it reads close to 0 ohms, it's shorted and you need to replace the relay. If you apply 12V to those pins the relay will close the contacts and pins 3 and 5 will connect. With 12V connected to pins 1/2, putting yer multimeter to pins 3/5 should give you a reading close to 0 ohms or if you have it on continuity, it should beep.
The Following User Says Thank You to BamZipPow For This Useful Post:
ajkalian (09-27-2011)
Old 09-26-2011, 05:41 AM   #11 (permalink)
Thanks again BZP.....great info!
Old 09-26-2011, 05:23 PM   #12 (permalink)
Well, I put in a new $36 starter relay and it's all good! Appreciate all the help and suggestions!!
Old 09-26-2011, 06:07 PM   #13 (permalink)
抵抗は無駄です
fenixus's Avatar
nice
Old 09-27-2011, 09:16 AM   #14 (permalink)
BamZipPow's Avatar
Wink
Glad that was only problem!
Click the button if you don't mind...
FishBut (10-10-2011)
