Oil in the Air Cleaner Intake Hose? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2011, 09:48 PM   #1 (permalink)
View dragonle87's Photo Gallery
I replaced the Air Cleaner Intake Hose (dry-rotted & was cracked open) on my 3.0L V6 Camry. I noticed when I was changing it out, there was oil inside the MAF housing, in the air cleaner intake hose, on throttle body plate.
Any suggestions?
dragonle87 is offline   Reply With Quote
Old 09-26-2011, 09:53 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
its pretty normal, unless it was a ton
Change the PCV valve and clean out the throttle.
carsrus is offline   Reply With Quote
Old 09-26-2011, 11:04 PM   #3 (permalink)
where is the PCV valve located?
Old 09-26-2011, 11:44 PM   #4 (permalink)
View armaniran's Photo Gallery
the pcv valve is located on the passenger side of the engine near the firewall , its about 5$ plus you'll need a grommet all togethor under 10$
the reason you have oil in the air filter is most likely because of a plugged pcv valve
armaniran is offline   Reply With Quote
Old 09-26-2011, 11:58 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yup, bad/clogged pcv valve will cause an excessive oil blow by to air intake (through the other PCV hose connected to air intake).
also a good idea to replace both hoses at same time, especially if they are cracked on ends or hardened/stiff (shouldn't be). dealers sell them each for a few bucks.
