Change or Don't Change Trans Fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Transmission Fluid becomes unchangeable?
Yes, it will become unchangeable in time 1 7.69%
No, it can always be replaced 11 84.62%
Don't know 1 7.69%
Voters: 13. You may not vote on this poll
Old 09-27-2011, 02:46 PM   #1 (permalink)
View Jarwulf's Photo Gallery
99 Camry LE 4 cylinder 2.2L 200000 miles
I know I've changed my transmission fluid but I'm not sure when. How much truth is there in the idea that you shouldn't change your transmission fluid ever again if it hasn't been changed after a certain amount of miles? What would be the mileage?
Jarwulf is offline   Reply With Quote
Old 09-27-2011, 07:24 PM   #2 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
Thats a myth the problem comes from people trying to fix a problem in theyr trans WITH a fluid change OR adding the wrong type / ammount
Now your saying its dirty...Do you think the transmission fluid is still doing its job? Wouldnt you think your transmission would benifit from fresh clean fluid?
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 09-27-2011, 10:05 PM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
You can drop the pan, clean it up, new filter and gasket whenever.
Its a flush that can dissolve so much gunk and varnish the trans will grenade. Pan drop only changes 40% or so of the fluid so it clean much more gradually.
carsrus is offline   Reply With Quote
Old 09-27-2011, 11:20 PM   #4 (permalink)
View WaxonWaxStillOn's Photo Gallery
There's a lot of "can happen" stories but I've never seen a "personally has happened" narrative in posts I've read while researching this on various googles/forum searches, including posts from long time mechanics that have never seen it happen.
Supposedly, if a transmission is on it's last leg, changing the fluid completely can potentially shorten that last leg...atleast that's what I've concluded from what I've read. But since it's rare, there are lots of different theories of when it could happen.
1994 Camry LE
4 cyl 2.2L 5SFE, 180k miles, tan
WaxonWaxStillOn is offline   Reply With Quote
Old 09-27-2011, 11:37 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
well generally I think that changing fluid in 99% of cases will do only good, especially if done on regular basis... that's called maintenance .. oh and there is no such thing as "lifetime" fluids ... or rather the definition of "lifetime" is misunderstood (usually in dealer's terms lifetime=100k miles).
however, if somebody totally completely neglected the transmission for 200k miles (if that can survive that long without breaking down) then yeah ... flushing the fluid can "harm it" meaning that probably all that crap, gunk, shit, dirt and additives inside it is needed to hold it back together and fill the excessive oil clearances and somewhat buildup some pressure ... but then again if someone neglected it THAT bad in first place, why would they care about such a nonsense as changing the fluid after all, huh?
Old 09-28-2011, 11:28 PM   #6 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
I think that changing trans fluid is almost always going to extend the life of a high mile/service, neglected atm, but I suppose that there is a remote possibility that fresh fluids (with a fresh dose of detergents), could loosen up some muck that might interfere with the hydraulics. Or maybe the fresh fluids could start engaging clutchs in a more firm and timely manner and quickly finish off heavily worn components... But such a failure would imply that it was ready to let go really soon anyway. It would take a serious forensic investigation to tell if a fluid change ever actually caused an automatic transmission to fail.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 09-29-2011, 01:53 AM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
I choose "dont know" because you left it as an option. Like others have said, I have never seen anyone have issues after a drain and fill. Flush is a different story. I have seen a couple trannys go south with high mileage after one. But thoes trannys were likely to do so anyways.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-29-2011, 12:06 PM   #8 (permalink)
double dose camry
View mail2_jb's Photo Gallery
I recently changed my ATF and Diff fluid (after checking TN of course) and so far car is running great (95k and 83k miles). I didn't know that you should be changing these fluids and my dealer never talked about it. Anyhow, i am planning to change them every year or 15-20k miles, it is just 20$ for mobile1 and I bet the trans will last a lot longer if proper fluid change is done.
mail2_jb is offline   Reply With Quote
