car doesnt shift into overdrive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2011, 09:26 PM   #1 (permalink)
View burnt clutch's Photo Gallery
My wife loaned her 94 Camry to a friend and now it won't shift down into overdrive. I looked under the hood and the throttle cable looks like this.
would this be related to the problem? Does anone have a picture of how the lower cable should look so I can refer to it when I put it back together? Thanks in advance for all replies!
-Karl
burnt clutch is offline   Reply With Quote
Old 09-28-2011, 09:51 PM   #2 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
For one, the cable is not attached to the bracket.
2, the cable looked stretched unless it is because it's hanging and not attached.
It could be related to the problem.
RichieRichJP is offline   Reply With Quote
Old 09-28-2011, 09:51 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 09-28-2011, 11:57 PM   #4 (permalink)
Just like he posted^
Old 09-29-2011, 01:05 AM   #5 (permalink)
View bolink654's Photo Gallery
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
Old 09-29-2011, 01:21 AM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
I don't think the friend would go under the hood? No?
Did you check the OD on/off switch? The OD light may have burned out? What's the coolant temperature reading?
Can you take a clearer picture of the cables? Why does the throttle linkage (lower one) look crooked?
Old 09-29-2011, 01:40 AM   #7 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
How many miles are on it? overdrive is the first thing to go on an automatic However the toyota automatic transmission is pretty reliable it could be some $15 solenoid
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
