Ultra Racing Strut Bar on a V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2011, 04:17 AM   #1 (permalink)
View Kandasan's Photo Gallery
4th Generation Ultra Racing Strut Bar on a V6
Hi guys
Does any one have experience with a Ultra Racing Strut Bar on a 1997 V6? UR's website and the Ebay seller didn't restrict this bar to a I4 Camry only. The problem I'm having is that it seems like.. something on the top of the throttle body is hitting the strut bar when I go in reverse only on a incline, but on a flat surface it's ok. I added washers to raise up the strut bar, and the noise seems to have gone away, but I'm not sure if that's ok. Another thing is am I supposed to remove the suspension support when installing the strut bar?
Thanks
Kandasan
Kandasan is offline   Reply With Quote
Old 10-02-2011, 10:49 AM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Strut bars are direct installation. Just unscrew the bolts that are holding the mounts in, and place the bar on those points and screw it back in. I wouldn't recommend putting washers in because it diminishes the stability of the strut bar's purpose. What's hitting it exactly, because strut bars are made to fit for that car, wouldn't matter much what engine displacement it is. Can you take a picture so that we can help you out a bit more?
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 10-02-2011, 12:41 PM   #3 (permalink)
Wagon Crew
swagger_wagon468's Avatar
Gameroom cash: $343652
View swagger_wagon468's Photo Gallery
Are your motor mounts bad? if so, that could be why the motor is hitting the bar.
thats my thought...
Shes on her way
Tint{X} Suspension{X} Camber Bolts{X} Rims{X} Sound System{X} Rear Spacers{} Header-Back Exhaust{} CAI{} Paint/Body/Kit{} Lights{}
swagger_wagon468 is offline   Reply With Quote
Old 10-02-2011, 04:11 PM   #4 (permalink)
- Xspeed here are the picture it looks like it could be the idle air valve. But without the washers the bar sits really close
-Swagger not sure about motors mounts I'll have to check that next
Old 10-02-2011, 05:03 PM   #5 (permalink)
Gameroom cash: $326045
View adalex's Photo Gallery
I can tell you what its hitting, its hitting the top of the bracket that holds the throttle cable. I'll take a pic in a few mins ( have washers too, but I'll take a pic of where it hits)
adalex is offline   Reply With Quote
Old 10-02-2011, 05:05 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
That is the EGR position sensor. Was the black residue on there before you installed the bar?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 10-02-2011, 05:27 PM   #7 (permalink)
oh the black residue is paint, because whatever hit the strut bar, could be the EGR Sensor, hit it hard enough to chip paint. So i wanted to cover it up just to avoid rust
Old 10-02-2011, 05:52 PM   #8 (permalink)
Avy
You can probably shave of a couple mm off the top of the sensor. I have a spare one so I'll see if that would affect the sensor.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 10-02-2011, 05:53 PM   #9 (permalink)
Thanks for your help.
Btw am i supposed to remove the suspension support when installing the bar?
Old 10-02-2011, 05:56 PM   #10 (permalink)
TN の がしょう
xpeed's Avatar
What is this suspension support you're talking about? Are you talking about the bolts that are holding the mounts in place?
Old 10-02-2011, 05:57 PM   #11 (permalink)
Avy
No, just un-bolt the 2 nuts on each strut mount, don't jack up the car, make sure its on the ground, on its on weight.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 10-02-2011, 05:57 PM   #12 (permalink)
Avy
suspension support/mount, same thing.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 10-02-2011, 06:04 PM   #13 (permalink)
I think on the technical manual it's called Suspension Support No.2
Old 10-03-2011, 02:03 AM   #14 (permalink)
TN の がしょう
xpeed's Avatar
No, you don't need to take it out. I'd keep it on.
Old 10-10-2011, 06:12 AM   #15 (permalink)
So I guess an update to this thread I guess I'm gonna need new motor mounts.
I lifted the strut bar up with washers and it seems to have gone away, but under even harder load you can hear taps.
This is the right side
this is the left side
