In an effort to be good to my car (1996 Avalon), I decided to replace the fuel filter. There's a very good DIY on how to do it :
http://hardlymoving.hubpages.com/hub...-Body-Cleaning
I noticed that the lower fuel line fitting was a little rounded off, but I figured that with my 14mm crowfoot flare nut wrench it wouldn't be a problem. I hit it with PB blaster several times as well. Well, it started to come off, about 1/2 turn would be my guess, then it just froze. Now I can't turn it any further out without rounding over the fitting and I can't get it to go back in without rounding. So, now I don't have a seal at the bottom of the filter. I can't drive it of course. So, any suggestions? The metal line (8mm) that attaches to the bottom of the filter runs all the way to the front of the gas tank, where there is a fitting as it joins a nylon fuel line that seems to be heading to the top of the tank. That fitting looks very corroded and I'd bet anything that any attempt to undo it will be met with more problems. Then I'd be looking at having to drop the tank and replace all the lines. One thought I had would be to splice it a new piece of metal or nylon line from somewhere just a short ways away from the filter and run that up into a new filter. However, I have no idea where I'd get the fittings, particularly one that would fit into the bottom of the filter. I'd appreciate any help.
