1999 Solara - RPM running high? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2011, 05:28 PM   #1 (permalink)
View VBrockel's Photo Gallery
I have a 1999 Solara - stock - 66,000 miles. It was my mothers' and she only drove it on Sundays.
It is running at 3000 RMP when traveling 70 MPH. Is this normal? A friend recently indicated that this was high.
If not normal, what could be the issue?
Thanks so much!
VBrockel is offline   Reply With Quote
Old 10-03-2011, 08:22 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yeah it is, V6 or I4? Is the O/D off or is it flashing? Have you tried changing the transmission and differential fluid?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 10-04-2011, 09:16 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
3k rpm for 70mph is way too high, something is wrong. I see 3k rpm on both 4 cylinder or 6 cylinder engines when driving at or slightly above 80mph (cruising on flat road, not climbing uphill or such).
pmesfun makes a good point, the over drive gear may not kicking in?
do a simple test, drive around to make the engine fully warmed up, then while cruising at or above 40mph, click the O/D button on shifter and note if it makes any difference. disabled O/D should light up "O/D off" on instrument panel, but most importantly you will feel car jumping to lower gear and increasing RPMs a bit.
draining & refilling the transmission (and differential, it's separate on 4 cylinder model) is ALWAYS a good idea. you could power flush if you want, but that's more challenging and if you let the shop do this they may charge you an arm and leg (dealer does around $200).
one more question, is the a Checking Engine Light on on instrument panel? if so, get the computer scanned at nearest Autozone or Advance Auto. write down the codes and post back.
EDIT: just noticed you are from California, they no longer do free code checking in stores over there for some reason...
