Car won't shift out of park - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2011, 10:48 AM   #1 (permalink)
View dustinastanton's Photo Gallery
I just changed the starter and battery in my '99 Solara. The car starts just fine now but I have no power to the interior and the car will not shift out of park. Any help is appreciated.
dustinastanton is offline   Reply With Quote
Old 10-04-2011, 11:26 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
when you press the brake pedal, do your tail lights light up?
The Following User Says Thank You to ghettosled For This Useful Post:
anti-seize (10-04-2011)
Old 10-04-2011, 12:06 PM   #3 (permalink)
View twodoorcamry's Photo Gallery
^ Good question
if not, see my recent car stuck in park thread, from when I had the same problem
Help to pinpoint Car stuck in Park issue
twodoorcamry is offline   Reply With Quote
Old 10-04-2011, 02:29 PM   #4 (permalink)
Tail lights do NOT light up. No turn signals either. Emergency flashers do work.
Old 10-04-2011, 04:51 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yeah, you need the tails to work (check the brake lights switch) in order to shift out from Park (otherwise you need to use override button by shifter's trim).
Old 10-04-2011, 06:46 PM   #6 (permalink)
View anti-seize's Photo Gallery
I'd take a good long look at your battery terminals, grounding cable, and positive cable. IIRC there's several wires that meet near the positive terminal. One goes down to the starter, others go around to various other parts. You just took them apart, so it's possible something got damaged.
Might as well check the fuses and fusable links too. I don't see any reason why they would blow during a battery R&R, but it's an easy check.
1994 Camry, 5SFE, automatic trans., 233k (it's a beater)
anti-seize is offline   Reply With Quote
Old 10-04-2011, 06:50 PM   #7 (permalink)
also, the starter is frequently used as a wiring harness "tie point" (thou I have zero experience with a Solara). Is it possible that you didn't get them all back in place?
Old 10-04-2011, 08:25 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
there STOP fuse, I believe 15A, behind the coin drawer. check it too as mentioned above.
