source for gaskets that go on timing belt covers Gen 3? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2011, 05:10 PM   #1 (permalink)
View anti-seize's Photo Gallery
does anyone know the toyota part numbers or have an aftermarket source of the gaskets for the timing belt covers?
I'm back inside again after only 30k miles because grease got inside the timing belt cover and we skipped a tooth (or three) on the belt. The symptoms were loss of low end torque and scary engine noises during idle. (I replaced all of the idlers and put in a new water pump last go-around)
1994 Camry, 5SFE, automatic trans., 233k (it's a beater)
anti-seize is offline   Reply With Quote
Old 10-04-2011, 09:55 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Rockauto has it, look for timing cover gasket set.
Amazon.com also sells it. Amazon.com also sells it.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
anti-seize (10-04-2011)
Tags
3sfe, gen3, timing belt
