93-94 camry carnk but doesnt start...please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2011, 10:53 PM   #1 (permalink)
View 91camry59's Photo Gallery
i have a 2.2L 93 camry with a 2.2 94 camry engine. i swap just the enigne only the 93 wire harness is with the 94 engine...tried to start it...it carnk but it doesnt start...check the spark plug and smelt fuel...so from what i can tell it must be some electrical problem but i dont know for sure...im thinking it could be the ecu because im using the 93 ecu...could someone help me please and thank you
91camry59 is offline   Reply With Quote
Old 10-05-2011, 02:04 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
How's the timing belt?
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-05-2011, 02:30 PM   #3 (permalink)
Timing belt s
Old 10-05-2011, 02:31 PM   #4 (permalink)
timing belt is new and water pump
Old 10-05-2011, 04:33 PM   #5 (permalink)
Bdub215's Avatar
Gameroom cash: $316065
View Bdub215's Photo Gallery
is the Map sensor hooked up?
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 10-05-2011, 09:56 PM   #6 (permalink)
View toovira's Photo Gallery
Does it start with starting fluid (don't put too much in - rinses oil off cylinder walls = bad)? If so, you got spark. If not, check ignition fuse...and follow the line....primary side of the ign coil, secondary side, then igniter, and also your distributors/rotor/caps and plug wires.
If ignition checks out, check your fuel pressure and EFI fuse.
Any check engine light? If so, read the code by shorting TE1/E1 pins.
toovira is offline   Reply With Quote
Old 10-06-2011, 02:40 AM   #7 (permalink)
prior to the engine swap the 94 engine started just fine...the engine sat for about 3-4 months...did the swap using all original parts from the 93(wire harness; ecu) the only difference is the engine..which is a 94...since the engine is a 94 and the ecu is a 93 will the ecu be a problem?
