Anyone with experience doing audio work on the 3rd gen w/ factory amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2011, 11:49 PM   #1 (permalink)
View AngryRedneck's Photo Gallery
3rd Generation Anyone with experience doing audio work on the 3rd gen w/ factory amp
I have a 1994 camry coupe w/ the tweeter/amp system. What i want to do is replace the factory head unit (tape, cd radio, double DIN) with a new double din unit, as well as add a single sub w/ amp.
From what i've read on here and other forums i have a single connecter in the back of the head unit vs. 2 for the non-amp system. So i need the single wiring harness adapter which i cant seem to find online. Crutchfield brings up parts for the non-amp stock system, not the one i have.
Does anyone have a link where i can buy the right harness adapter? And any other parts i might need for this?
Thanks.
AngryRedneck is offline   Reply With Quote
Old 10-06-2011, 12:15 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
You should have two connectors that plug into a harness that run to the amplifier, disconnect those, and use that to connect to your new system. In other words, get the adapter harness for the Camry's with the stereo/built in amp. I hope that makes sense.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 10-06-2011, 12:26 AM   #3 (permalink)
Ah thanks. I took another look at this pdf after your reply: http://www.installdr.com/installdocs...PDF/869013.asp
So basically both systems have the 2 plugs, just the one for the amp system connects into one in the back of the stock radio. Therefore the regular wiring harness adapter should work fine.
Old 10-06-2011, 12:29 AM   #4 (permalink)
71Corolla's Avatar
Yes you got it. At least all the ones I've seen were that way. You can easily verify this, to the right of the head unit you should see the harness and the two connectors.
