Originally Posted by Jonate
There have been a few TN member who wanted the same set, and while they did find companies who had them, they never found the company where I got mine from for far less than the others. I guess I've held on to that secret long enough. So, here you go...
http://www.procarparts.com/index.php...ducts_id=36302
Originally Posted by Aetebet
Nice! Could you give some info on what is needed to do this? I found some Gen 5 steering wheels on eBay for about $50 w/o airbags and $150 with. I'm guessing I'd just need to buy the wheel and airbag. Solara and Celica wheels also look similar to Gen 5's, would one of those work? There might be one cheaper so I'd like to keep it as an option...
1) the Wheel and airbag of course
2) a set of matching airbag connectors. I got mine from ebay. You'll only need the orange one, but they come as a set.
3) the air bag connector from a gen3/4. You can either cut this off of your current airbag, or find a gen3/4 in the junkyard with an intact(non-deployed) airbag, and it off of that one.
You'll use items 2, and 3 to make an adapter for the new airbag.
4) the cruise control lever from your current wheel. Here's a pick of my gen3.5 CC lever (bottom) next to the gen5 CC lever(top). As you can see, they have the same mounting points.
Here's a pic of the my gen3.5 CC lever installed in the gen5 wheel.
The black wire from the CC lever will either need a connector to attach to the metal tab of the wheel(grounding point), or you you can solder it to that tab. I used a connector.
That's it...simple as that.
